Salta al contenuto principale
Introduzione
Over time, you may notice the performance of the battery on your Q700 degrades as it ages. If your battery life is no longer acceptable, follow these instructions to replace it.
  1. Remove the battery cover of this device by sliding it down and then lifting it up.
    • Remove the battery cover of this device by sliding it down and then lifting it up.
  2. Use the plastic opening tool provided in the toolkit to safely remove the battery.
    • Use the plastic opening tool provided in the toolkit to safely remove the battery.
    • Never use a metal tool to work with lithium-ion batteries, it may puncture and explode!
  3. Remove the battery from the device.
    • Remove the battery from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Rich
Membro da: 08/04/2013
125 Reputazione
6 Guide realizzate
SUNY Cortland, Team 1-4, Getto Spring 2013 Membro di SUNY Cortland, Team 1-4, Getto Spring 2013
SUNYCORT-GETTO-S13S1G4
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 373
