Salta al contenuto principale
Motorola Q Global Speakers Replacement
Cosa ti serve
  1. Motorola Q Global Speakers Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Speakers Replacement: passo 2, immagine 1 di 2 Motorola Q Global Speakers Replacement: passo 2, immagine 2 di 2
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Speakers Replacement, Speakers: passo 3, immagine 1 di 1
    • Press inwardly on the upper casing until it pops out of the phone.
  4. Motorola Q Global Speakers Replacement: passo 4, immagine 1 di 1
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  5. Motorola Q Global Speakers Replacement: passo 5, immagine 1 di 2 Motorola Q Global Speakers Replacement: passo 5, immagine 2 di 2
    • Remove the six labeled screws with a T5 torx screw driver.
  6. Motorola Q Global Speakers Replacement: passo 6, immagine 1 di 1
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Speakers Replacement: passo 7, immagine 1 di 1
    • Remove the speakers by using the plastic remover tool.
  8. Motorola Q Global Speakers Replacement: passo 8, immagine 1 di 1
    • Insert the new speakers by gently pressing them down into place.
Conclusione
Cal Poly, Team 6-31, Regan Fall 2012 Membro di Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 626
