Salta al contenuto principale
Motorola Q Global Display screen Replacement
Cosa ti serve
  1. Motorola Q Global Display screen Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Display screen Replacement: passo 2, immagine 1 di 2 Motorola Q Global Display screen Replacement: passo 2, immagine 2 di 2
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Display screen Replacement, Display screen: passo 3, immagine 1 di 1
    • Press inwardly on the upper casing to release.
  4. Motorola Q Global Display screen Replacement: passo 4, immagine 1 di 1
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  5. Motorola Q Global Display screen Replacement: passo 5, immagine 1 di 2 Motorola Q Global Display screen Replacement: passo 5, immagine 2 di 2
    • Remove the 6 screws using the T5 torx screwdriver.
  6. Motorola Q Global Display screen Replacement: passo 6, immagine 1 di 1
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Display screen Replacement: passo 7, immagine 1 di 2 Motorola Q Global Display screen Replacement: passo 7, immagine 2 di 2
    • Remove both screws on the mounted surface with a T5 screwdriver.
  8. Motorola Q Global Display screen Replacement: passo 8, immagine 1 di 2 Motorola Q Global Display screen Replacement: passo 8, immagine 2 di 2
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
  9. Motorola Q Global Display screen Replacement: passo 9, immagine 1 di 2 Motorola Q Global Display screen Replacement: passo 9, immagine 2 di 2
    • Lift the motherboard about 90 degrees and remove the circuit with the orange ribbon (from the keyboard) by gently lifting the circuit.
  10. Motorola Q Global Display screen Replacement: passo 10, immagine 1 di 2 Motorola Q Global Display screen Replacement: passo 10, immagine 2 di 2
    • Separate the front plate from the circuit board.
    • The LCD screen is attached to the circuit board by a thin ribbon.
    • Switch the lock on top of the circuit entry from horizontal to vertical.
  11. Motorola Q Global Display screen Replacement: passo 11, immagine 1 di 1
    • Insert the new LCD screen into the circuit.
Conclusione
Will Dickman
Membro da: 09/27/12
28 Reputazione
3 Guide realizzate
Cal Poly, Team 6-31, Regan Fall 2012 Membro di Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 848
