Introduzione
If you are unable to hear from the speaker, then the speaker may be faulty. This is a guide on how to replace the speaker.
Cosa ti serve
Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
Lift the back cover from the bottom and remove it from the phone.
Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
Remove the battery from your phone.
Remove all five screw covers with tweezers located in the picture.
Remove the 10 T4 Torx screws securing the midframe to the display assembly.
Gently pry the midframe from the display assembly and remove it.
Use the Metal Spudger to get between the speaker and the midframe and slowly lift the speaker upwards.
Remove the speaker from the midframe.
