Salta al contenuto principale
Motorola Photon 4G MB855 Motherboard Replacement
Cosa ti serve
  1. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Back Cover: passo 1, immagine 1 di 2 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Back Cover: passo 1, immagine 2 di 2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Battery: passo 2, immagine 1 di 2 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Battery: passo 2, immagine 2 di 2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: passo 3, immagine 1 di 3 Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: passo 3, immagine 2 di 3 Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: passo 4, immagine 1 di 3 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: passo 4, immagine 2 di 3 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: passo 4, immagine 3 di 3
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: passo 5, immagine 1 di 3 Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: passo 5, immagine 2 di 3 Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: passo 5, immagine 3 di 3
    • Locate the Display Data Cables
    • Use hands or plastic opening tool to carefully pry off the connectors.
  6. Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: passo 6, immagine 1 di 3 Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: passo 6, immagine 2 di 3 Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: passo 6, immagine 3 di 3
    • Be careful when removing the motherboard. The earpiece is connected with small wires and adhesive. Use a thin tool to pry it off before removing the motherboard.
    • Use a plastic opening tool to gently pry off each section of the Motherboard.
    • Slowly and carefully remove the motherboard from the front panel assembly.
Conclusione
Altre 4 persone hanno completato questa guida.
Eddie Krause
Membro da: 10/07/14
260 Reputazione
3 Guide realizzate
USF Tampa, Team 8-6, Leahy Fall 2014 Membro di USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,392
