Introduzione
If your phone is malfunctioning and you cannot fix it through other guides, the motherboard may need to be replaced. Use this guide to replace the motherboard.
Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
  • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
  • Lift the back cover from the bottom and remove it from the phone.
Aggiungi Commento
Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
  • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
  • Remove the battery from your phone.
Aggiungi Commento
  • Remove all five screw covers with tweezers located in the picture.
Aggiungi Commento
  • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
  • Gently pry the midframe from the display assembly and remove it.
Aggiungi Commento
  • Locate the Display Data Cables
  • Use hands or plastic opening tool to carefully pry off the connectors.
Aggiungi Commento
  • Be careful when removing motherboard. Earpiece is connected with small wires and adhesive. Use thin metal tool to pry off before removing motherboard.
  • Use a plastic opening tool to gently pry off each section of the Motherboard.
  • Use hands to slowly and carefully remove the motherboard from the front panel assembly.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Eddie Krause
Membro da: 07/10/2014
262 Reputazione
3 Guide realizzate
USF Tampa, Team 8-6, Leahy Fall 2014 Membro di USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 898
