Introduzione
Use this guide to replace the midframe on your Photon 4G.
Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
  • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
  • Lift the back cover from the bottom and remove it from the phone.
Aggiungi Commento
Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
  • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
  • Remove the battery from your phone.
Aggiungi Commento
  • Remove all five screw covers with tweezers located in the picture.
Aggiungi Commento
  • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
  • Gently pry the midframe from the display assembly and remove it.
Aggiungi Commento
Conclusione
Eddie Krause
Membro da: 07/10/2014
262 Reputazione
3 Guide realizzate
USF Tampa, Team 8-6, Leahy Fall 2014 Membro di USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 190
