Salta al contenuto principale
Motorola Nextel i880 Antenna Replacement
Cosa ti serve
  1. Motorola Nextel i880 Antenna Replacement, Antenna: passo 1, immagine 1 di 1
    • Remove back cover of the phone by disengaging the clip and lifting up on the cover.
  2. Motorola Nextel i880 Antenna Replacement: passo 2, immagine 1 di 1
    • Locate the screw on the top left portion of the phone; just below the antenna. Using a T4 Torx screwdriver remove the screw.
  3. Motorola Nextel i880 Antenna Replacement: passo 3, immagine 1 di 1
    • Slide antenna out of the phone. Ensure that the protective plastic sleeve is not lost in removal.
  4. Motorola Nextel i880 Antenna Replacement: passo 4, immagine 1 di 1
    • Slide and secure new antenna into position. Make sure metal receiver is facing forward.
  5. Motorola Nextel i880 Antenna Replacement: passo 5, immagine 1 di 1
    • Reattach back cover and secure all components in place.
Conclusione
Ryan
Membro da: 10/19/14
9 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 196
