Salta al contenuto principale
Motorola Moto Z2 Play Speaker Replacement
Cosa ti serve
  1. Motorola Moto Z2 Play Speaker Replacement, Screen Removal: passo 1, immagine 1 di 1
    • Power off your phone before you complete any replacement steps.
  2. Motorola Moto Z2 Play Speaker Replacement: passo 2, immagine 1 di 1
    • Heat the edges of your Motorola Moto Z2 Play screen for two to three minutes with a heat gun. You adjust the heat gun to 85 degrees centigrade, and be careful not to hold the heat gun on one position for too long; to avoid damaging, or "hotspotting" the LCD. The screen should be very warm, but not painful, to the touch. Reheat as necessary.
    • If screen is cracked put strong adhesive tape across the screen in order to avoid breaking the screen further and receiving cuts.
    • If you don’t have access to a heat gun, a hair dryer can be used.
  3. Motorola Moto Z2 Play Speaker Replacement: passo 3, immagine 1 di 1
    • Place suction cup in the middle of the screen and press down.
  4. Motorola Moto Z2 Play Speaker Replacement: passo 4, immagine 1 di 3 Motorola Moto Z2 Play Speaker Replacement: passo 4, immagine 2 di 3 Motorola Moto Z2 Play Speaker Replacement: passo 4, immagine 3 di 3
    • Pry the screen by wedging the plastic opening tool under the screen at the charging port.
    • Work your way around the screen with the plastic opening tool.
    • When you pry near the top-right and bottom-right corners, be careful not to pry too far, or you risk damaging the display cable.
    • Complete these steps carefully because the screen is delicate and can easily crack. If the screen begins to resist prying, reheat the adhesive with your heat gun.
  5. Motorola Moto Z2 Play Speaker Replacement: passo 5, immagine 1 di 3 Motorola Moto Z2 Play Speaker Replacement: passo 5, immagine 2 di 3 Motorola Moto Z2 Play Speaker Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Use a suction cup to lift up screen from left to right.
    • If you don’t have a suction cup, wedge a spudger or a small plastic card under the screen and lift slowly.
    • Failure to lift screen from left to right can cause damage to interior wires of your phone.
  6. Motorola Moto Z2 Play Speaker Replacement: passo 6, immagine 1 di 3 Motorola Moto Z2 Play Speaker Replacement: passo 6, immagine 2 di 3 Motorola Moto Z2 Play Speaker Replacement: passo 6, immagine 3 di 3
    • Identify ribbon connector at the top right of the phone.
    • Pry the black locking bar up gently with a plastic opening tool.
    • Remove the ribbon wires by pulling them out of the connector with a tweezer.
    • The locking bar is the small black bar located on the digitizer’s ZIF connector.
    • Be sure to push the locking bar back down using a spudger after you put the ribbon wire back in since the lock does not lock automatically.
  7. Motorola Moto Z2 Play Speaker Replacement: passo 7, immagine 1 di 3 Motorola Moto Z2 Play Speaker Replacement: passo 7, immagine 2 di 3 Motorola Moto Z2 Play Speaker Replacement: passo 7, immagine 3 di 3
    • Identify the ribbon cable, located at the bottom right of the phone.
    • If present, remove kapton (orange) tape covering the cable connector.
    • Flip up the small locking flap on the ZIF connector and use tweezers to slide the cable straight out of its socket.
    • Excessive force is not needed.
  8. Motorola Moto Z2 Play Speaker Replacement: passo 8, immagine 1 di 1
    • Lift the screen from the phone to completely detach.
    • If screen doesn't detach, go back to step 7 and 8 to make sure the bar is unlocked and ribbon connector is fully detached.
    • During reassembly, you may need to apply or replace the display adhesive on your display assembly. Use our display adhesive application guide to apply the adhesive and reseal your device.
  9. Motorola Moto Z2 Play Speaker Replacement, Battery: passo 9, immagine 1 di 2 Motorola Moto Z2 Play Speaker Replacement, Battery: passo 9, immagine 2 di 2
    • Remove the orange tape, located at the bottom right of the phone, using tweezers.
    • Do not discard tape.
    If you discard the gold tape it can cause the phone to reset after repair
    JT Harper - Replica
  10. Motorola Moto Z2 Play Speaker Replacement: passo 10, immagine 1 di 2 Motorola Moto Z2 Play Speaker Replacement: passo 10, immagine 2 di 2
    • Detach the red and black battery wire by lifting up with tweezers.
    What if the whole black box came off. I think i broke it! :( is this fixable?
    Rachael Vigar - Replica
  11. Motorola Moto Z2 Play Speaker Replacement: passo 11, immagine 1 di 2 Motorola Moto Z2 Play Speaker Replacement: passo 11, immagine 2 di 2
    • Peel back the black tape that is located on the battery.
    • Make sure you pull back gently so you can reuse the tape with reassembly.
  12. Motorola Moto Z2 Play Speaker Replacement: passo 12, immagine 1 di 3 Motorola Moto Z2 Play Speaker Replacement: passo 12, immagine 2 di 3 Motorola Moto Z2 Play Speaker Replacement: passo 12, immagine 3 di 3
    • Lift the black tape and slide a card under the battery.
    • Align the card parallel and under the battery.
    • Wedge the card further under the battery.
    • Lift the card up to assist in removing the battery from the adhesive.
  13. Motorola Moto Z2 Play Speaker Replacement: passo 13, immagine 1 di 1
    • Lift to remove the battery from the device completely.
    Why can't they just go back to the phones where you can snap off the back and simply replace the battery? I'm afraid to do it myself and Verizon won't do it for me. Now I have to find someone whom I will have to pay to replace a battery. This is ridiculous. It should not be so difficult to replace a battery and I should not have to jeopardize my phone to replace a battery. Why? Sorry, I just needed to vent. I miss simplicity.
    spallatto - Replica
    I agree with both of you guys, but it’s the breaking point between performance, convenience, and safety. Older phones had batteries with hard protective casings that wouldn’t leave them vulnerable to pocket-fire if your keys jammed the battery.
    Unfortunately, with phones getting more powerful(requiring a higher-capacity battery), AND slimmer, the protective casing for the battery is literally the casing on the phone. Look at the battery above; it could easily be pierced and dangerously vent.
    I’m with you in wishing I could just pop a spare in, but those days have passed. =/
    Mike Ponce - Replica
    I suggest NOT to do this. Followed the directions exactly, with the slight deviation of my cable into the battery crumbling so I carefully pulled out the lose pieces with the tweezers and had NO problem putting it back together. My phone was WORKING with the exploded, puffy battery with NO deficits. Now? No charging (but checked it with the multi-meter so I know it is not the fault of the new battery). Only reaction I get is the phone making a vibrating sound when I plug it in to charge. Will NOT turn on. Will NOT react. F*CKED.
    Jeanne M Taylor - Replica
    Without knowing what I was getting into I ordered a replacement battery, toolkit, and screen adhesive. Thanks to this guide I was actually able to remove the screen, replace the battery, and get it sealed back up relatively easily. Definitely nerve-wracking as I haven’t attempted anything like this before, but my phone was at the end of the battery life so I figured why not give it a shot.
    Thank you for the easy instructions!
    Alex Anderson - Replica
    i followed the guide step by step, but unfortunately i touched the lcd in one place ... with the result that the screen went KO can i fix it somehow?
    erryedelia - Replica
  14. Motorola Moto Z2 Play Speaker Replacement, Speaker: passo 14, immagine 1 di 1
    • Remove the three silver 2.6 mm T3 Torx screws on the speaker shell at the top of the phone with a screwdriver by turning counterclockwise.
    • Remove the four black 3.5 mm T3 Torx screws on the speaker shell at the top of the phone with a screwdriver by turning counterclockwise.
    • It is helpful to keep screws on a magnetic surface to avoid losing them.
  15. Motorola Moto Z2 Play Speaker Replacement: passo 15, immagine 1 di 1
    • Lift up the silver metallic tape using the tweezers.
  16. Motorola Moto Z2 Play Speaker Replacement: passo 16, immagine 1 di 3 Motorola Moto Z2 Play Speaker Replacement: passo 16, immagine 2 di 3 Motorola Moto Z2 Play Speaker Replacement: passo 16, immagine 3 di 3
    • Lift gently to completely remove speaker housing using tweezers.
    • Try lifting the speaker housing from both sides slightly before removing completely.
  17. Motorola Moto Z2 Play Speaker Replacement: passo 17, immagine 1 di 2 Motorola Moto Z2 Play Speaker Replacement: passo 17, immagine 2 di 2
    • Place the housing upside down in order to continue working.
    • Pry the speaker from the housing with a plastic opening tool.
    • When reassembling, make sure the metal connectors of speaker are in the bottom left and right corners (correct orientation).
    • Speaker clicks in on reassembly.
Conclusione
mitch miller
Membro da: 01/24/18
2.055 Reputazione
8 Guide realizzate
Cal Poly, Team S19-G5, Livingston Winter 2018 Membro di Cal Poly, Team S19-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G5
4 Membri
30 Guide realizzate
Un commento
Hi,
The guide was very detailed, kudos to that. Recently My phone fell of from my hand into glass of whisky :( hopefully no physical damage and i speedily switched off and dried it off . I tried to find any fault i found that when I am trying to play music through google music, youtube, any app or trying to call i am not able to hear any sound, yet the phone ringtone works, absolutely fine. Bluetooth and headphone jack when used its fine.
first . when i am dialing someone i am not able to hear any sound through normal ear piece, but i am able to hear when sound speaker is put on.
secondly, I am not able to hear any sound while playing videos or music in any app be it any app, chrome, youtube, google music.
Can you suggest me that what can be the issue..?
jacob alexander - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,318
