Introduzione
If your Moto Z2 Force screen is cracked or not operating correctly, use this guide for the steps to replace it.
  1. Place the phone on a flat surface with the screen facing up.
    • Place the phone on a flat surface with the screen facing up.
    • Insert the flat end of a nylon spudger into the crease separating the screen and the body in the lower right corner of the phone.
    • Pry open part of the screen by pulling the tool and the screen toward you.
    • You may be required to use a heating element, such as the iOpener, to heat and loosen the adhesive underneath before attempting to pry it open.
  2. Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open.
    • Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open.
    • Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you.
    • Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
    • Remove the screen gently and slowly as the screen may crack otherwise.
    • Remove the screen by pulling from right to left and placing the screen face down on the flat surface next to the main body of the device.
    • Using the flat end of the nylon spudger, pull off the black tape on top of the screen connector piece that the black ribbon is attached to.
    • Insert the black spudger under the lock of the latch connecting the black ribbon of the screen to the phone body.
    • Pull up on the lock to unlock the latch.
    • Separate the black ribbon from the latch by pulling gently to the left.
Conclusione
Altre 5 persone hanno completato questa guida.
Amelia Fruda
Membro da: 24/01/2018
307 Reputazione
1 Guida realizzata
Cal Poly, Team S2-G1, Livingston Winter 2018 Membro di Cal Poly, Team S2-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G1
4 Membri
6 Guide realizzate
What about installing the new screen?
John - Replica
lol exactly what i was thinking, john!!
like what the !&&*….guide us thru removing the entire screen and then just leave us with our d in our hand lol
PETE ZITO - Replica
Just do the same thing backwards.
Jade Davis -
Can I use a z2 play screen on the z2 force?
Paulo Alberto Werhli Meier - Replica
You can but they have a big difference the LCD pixelation. The Z2 Force has 2,560x1,440 pixel resolution while the play has a 1,920x1,080 resolution. So even thought it can be done it is not recommended.
Cole Jensen -
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 96
Ultimi 30 Giorni: 470
Tutti i Tempi: 5,152
