Salta al contenuto principale
Motorola Moto X4 Rear Camera Replacement
Cosa ti serve
  1. Motorola Moto X4 Rear Camera Replacement, Heat the screen: passo 1, immagine 1 di 2 Motorola Moto X4 Rear Camera Replacement, Heat the screen: passo 1, immagine 2 di 2
    • Before you begin, turn off your phone.
    • Heat an iOpener and apply it to the left edge of the phone for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take note of the the following areas:
    • Display cable—be careful not to slice too deeply near the edge here, or you may damage the display cable.
    • Fingerprint sensor cable—be careful not to slice too deeply near the edge here, or you may damage the fingerprint sensor cable.
    Complete novice. Getting old screen off was time consuming! I was too afraid of ruining something by overheating. Spent many hours trying to use iopener, afraid to risk bursting it in microwave. Read many comments in the iopener use guide; a guy said to get the screen temp up to 120-130F. Saw several youtube videos esp. Witrig one on replacing Moto x4 screen, they used heat gun 100C=212F so I got braver and put my phone on kitchen hot plate. Measured temperature by laying stem of candy thermometer on the surface. When hot plate got to 150-160F I finally got a pick under phone ‘s glass edge & got the screen off. Hot plate temp. not stable, guess phone was there a few minutes. May have damaged display but was replacing it anyway. Now new screen installed everything working properly! I’m not sure I was using the suction cup when I finally was able to push the pick under the edge.
    Nahariyah Mosenkis - Replica
  2. Motorola Moto X4 Rear Camera Replacement, Create a gap: passo 2, immagine 1 di 3 Motorola Moto X4 Rear Camera Replacement, Create a gap: passo 2, immagine 2 di 3 Motorola Moto X4 Rear Camera Replacement, Create a gap: passo 2, immagine 3 di 3
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • Pull on the suction cup with strong, steady force to create a gap in the seam.
    • Insert the point of an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    On the left side it is a very thin strip of adhesive—but there are other places where there is alot more adhesive—If you look at the black part of the new adhesive-if you have the phone specific adhesive thing—you will get an idea what you might be trying to push through at any given spot on the phone. orient the new one over the old screen to line up holes etc-to understand where the adhesive is.
  3. Motorola Moto X4 Rear Camera Replacement, Slice the screen adhesive: passo 3, immagine 1 di 3 Motorola Moto X4 Rear Camera Replacement, Slice the screen adhesive: passo 3, immagine 2 di 3 Motorola Moto X4 Rear Camera Replacement, Slice the screen adhesive: passo 3, immagine 3 di 3
    • Slide the opening pick along the edge to slice through the adhesive.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  4. Motorola Moto X4 Rear Camera Replacement: passo 4, immagine 1 di 3 Motorola Moto X4 Rear Camera Replacement: passo 4, immagine 2 di 3 Motorola Moto X4 Rear Camera Replacement: passo 4, immagine 3 di 3
    • Heat the top edge of the phone with an iOpener.
    • Carefully slice around the corner and through the top edge to separate the adhesive.
  5. Motorola Moto X4 Rear Camera Replacement: passo 5, immagine 1 di 3 Motorola Moto X4 Rear Camera Replacement: passo 5, immagine 2 di 3 Motorola Moto X4 Rear Camera Replacement: passo 5, immagine 3 di 3
    • Heat the screen's right edge with an iOpener.
    • Be careful not to slice too deeply near the cables to avoid damaging them.
    • Use an opening pick to slice along the right edge to separate the adhesive.
  6. Motorola Moto X4 Rear Camera Replacement: passo 6, immagine 1 di 2 Motorola Moto X4 Rear Camera Replacement: passo 6, immagine 2 di 2
    • Repeat the previous steps to heat and slice the bottom edge of the phone.
  7. Motorola Moto X4 Rear Camera Replacement: passo 7, immagine 1 di 2 Motorola Moto X4 Rear Camera Replacement: passo 7, immagine 2 di 2
    • Do not try to remove the screen yet—it is still attached to the phone by delicate flex cables.
    • Carefully lift up the left edge of the screen and cut away remaining adhesives with an opening pick.
  8. Motorola Moto X4 Rear Camera Replacement: passo 8, immagine 1 di 1
    • Swing open the screen and prop it up with a small box as you work on disconnecting the flex cables.
    • During reassembly, this is a good time to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  9. Motorola Moto X4 Rear Camera Replacement, Detach the fingerprint sensor cable: passo 9, immagine 1 di 2 Motorola Moto X4 Rear Camera Replacement, Detach the fingerprint sensor cable: passo 9, immagine 2 di 2
    • Slide the point of a spudger underneath the fingerprint sensor cable and gently pry up to loosen the cable from the phone.
    • Do not pull on the cable. It is still attached to the phone by a delicate ZIF socket.
  10. Motorola Moto X4 Rear Camera Replacement, Disconnect the fingerprint sensor: passo 10, immagine 1 di 3 Motorola Moto X4 Rear Camera Replacement, Disconnect the fingerprint sensor: passo 10, immagine 2 di 3 Motorola Moto X4 Rear Camera Replacement, Disconnect the fingerprint sensor: passo 10, immagine 3 di 3
    • Use the point of a spudger to flip up the lock bar on the fingerprint sensor's ZIF socket, near the bottom right of the phone.
    • Use tweezers to carefully slide the fingerprint sensor cable out of the socket.
  11. Motorola Moto X4 Rear Camera Replacement, Disconnect the display cable: passo 11, immagine 1 di 3 Motorola Moto X4 Rear Camera Replacement, Disconnect the display cable: passo 11, immagine 2 di 3 Motorola Moto X4 Rear Camera Replacement, Disconnect the display cable: passo 11, immagine 3 di 3
    • Use an opening tool to flip up the wide lock bar on the display cable's ZIF socket, near the top right of the phone.
    • Use tweezers to carefully slide the display cable out of the ZIF socket.
  12. Motorola Moto X4 Rear Camera Replacement, Remove the screen: passo 12, immagine 1 di 2 Motorola Moto X4 Rear Camera Replacement, Remove the screen: passo 12, immagine 2 di 2
    • Remove the screen.
    • During reassembly, follow this guide to clean the existing adhesive off and install custom-cut adhesives for your phone.
    I found that the subsequent steps will be smoother if you spend a little time at this point cleaning out the old adhesive pieces. The picture above shows pulling off some of the old glue strips, but the bullet points don’t mention it. Removing the mid-frame and other steps is easier if the old adhesive has been cleaned out.
    Gordon Bolt - Replica
    Good point Gordon! I’ve adjusted the wording on the second bullet to point people in the right direction.
    Arthur Shi -
    I’d already used the free form adhesives to glue the screen back on before I realized the kit came with a ready-to-go adhesive sheet. It’d be nice if this were mentioned (or pictured) here.
    Paul Ferrell - Replica
    The provided replacement screen does not have the black plastic film w/ 5 x 3 holes in it
    photo to illustrate: top is replacement screen. Bottom is old screen, w/ black film w/ holes
    Not sure how to proceed here.
    Etienne Grossmann - Replica
  13. Motorola Moto X4 Rear Camera Replacement, Unscrew the midframe: passo 13, immagine 1 di 2 Motorola Moto X4 Rear Camera Replacement, Unscrew the midframe: passo 13, immagine 2 di 2
    • Remove the following twenty screws securing the midframe:
    • Eleven silver 2.7 mm-long T3 screws
    • Nine black 3.6 mm-long T4 screws
    • The midframe is still held in place by clips.
    For some reason, my brand new T4 screwdriver didn’t fit the 9 designated T4 screws very well—it seemed a little large. So I carefully tried the T3 screwdriver and it worked perfectly! Not sure if the head has changed sizes on those longer screws in some assemblies….
    Kenneth Lassman - Replica
    Hi Kenneth! I’m glad the T3 worked! There have been many instances with Moto phones where the screw tolerances are quite variable—they normally shows up in the T3-T4 range.
    Arthur Shi -
  14. Motorola Moto X4 Rear Camera Replacement, Loosen the midframe: passo 14, immagine 1 di 3 Motorola Moto X4 Rear Camera Replacement, Loosen the midframe: passo 14, immagine 2 di 3 Motorola Moto X4 Rear Camera Replacement, Loosen the midframe: passo 14, immagine 3 di 3
    • The next few steps show how to loosen the midframe clips.
    • Insert the flat end of a spudger under the right edge of the metal midframe and pry up to loosen the midframe.
    • Insert an opening pick in the edge to hold the midframe in place.
  15. Motorola Moto X4 Rear Camera Replacement: passo 15, immagine 1 di 2 Motorola Moto X4 Rear Camera Replacement: passo 15, immagine 2 di 2
    • Insert the flat end of a spudger under the lower right edge of the midframe and pry up to release the midframe clip.
  16. Motorola Moto X4 Rear Camera Replacement: passo 16, immagine 1 di 3 Motorola Moto X4 Rear Camera Replacement: passo 16, immagine 2 di 3 Motorola Moto X4 Rear Camera Replacement: passo 16, immagine 3 di 3
    • Grasp the lower edge of the midframe and pull the edge slightly to the right, to clear the metal midframe clip.
  17. Motorola Moto X4 Rear Camera Replacement: passo 17, immagine 1 di 2 Motorola Moto X4 Rear Camera Replacement: passo 17, immagine 2 di 2
    • Insert the point of an opening pick under the top left corner of the midframe and twist slightly to release the top clip.
  18. Motorola Moto X4 Rear Camera Replacement, Remove the midframe: passo 18, immagine 1 di 3 Motorola Moto X4 Rear Camera Replacement, Remove the midframe: passo 18, immagine 2 di 3 Motorola Moto X4 Rear Camera Replacement, Remove the midframe: passo 18, immagine 3 di 3
    • Remove the midframe.
    • To reinstall the midframe:
    • Align the the midframe's top edge to the phone and press it into position.
    • Shift the bottom edge slightly to the left, to maneuver the left metal midframe clip underneath the phone edge.
    • Press the midframe's bottom edge into position.
  19. Motorola Moto X4 Rear Camera Replacement, Disconnect the battery: passo 19, immagine 1 di 2 Motorola Moto X4 Rear Camera Replacement, Disconnect the battery: passo 19, immagine 2 di 2
    • Insert the point of a spudger underneath the top edge of the battery connector.
    • Be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Gently pry up the connector to disconnect the battery.
  20. Motorola Moto X4 Rear Camera Replacement: passo 20, immagine 1 di 3 Motorola Moto X4 Rear Camera Replacement: passo 20, immagine 2 di 3 Motorola Moto X4 Rear Camera Replacement: passo 20, immagine 3 di 3
    • To re-connect the battery, align the connector on top of the socket, and press it down with your finger or a spudger.
    After disconnecting the battery, there is 1x T3 (near the camera) and 2xT4 screws (near the headphone jack and usb port) that had to be removed, then the camera clips flipped up, then that board carefully removed (after ejecting the sim/memory cards) before being able to get to the two screws for the camera module.
    For reassembly, the camera cables had to be carefully held back while the board was repositioned.
    Steve Welander - Replica
    Hi Steve,
    Thanks for the feedback! What you are describing sounds like the steps found in this guide. Can you see if anything is missing there? Thanks!
    Arthur Shi -
    Hi Arthur, I am doing this repair right now, and yes, this guide should have steps 21-25 from the linked guide inserted after step 20. Getting to the Rear Camera requires removing the motherboard, and indeed you can see in the pictures in what is currently Step 21 of this guide that the motherboard is removed (note the missing large silver rectangle in the upper-left, which is the SIM card tray, for instance, or any electronics in the upper-right)
    Joel Bradshaw - Replica
    Although notably, the vibrating motor doesn’t have to be unplugged from the socket, just removed from the case along with the motherboard. I advise that, as the motor’s connection is very small and fragile.
  21. Motorola Moto X4 Rear Camera Replacement, Rear Camera: passo 21, immagine 1 di 2 Motorola Moto X4 Rear Camera Replacement, Rear Camera: passo 21, immagine 2 di 2
    • Using a T3 Torx screwdriver, remove both 1cm screws. To do this, insert the screwdriver into the head of the screw, then turn counter-clockwise.
  22. Motorola Moto X4 Rear Camera Replacement: passo 22, immagine 1 di 2 Motorola Moto X4 Rear Camera Replacement: passo 22, immagine 2 di 2
    • Use the tweezers to gently lift the rear camera up and out of your Moto X4.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto X4 Answers community for help.
Altre 3 persone hanno completato questa guida.
Brian Buchanan
Membro da: 01/24/18
1.047 Reputazione
5 Guide realizzate
Cal Poly, Team S18-G4, Livingston Winter 2018 Membro di Cal Poly, Team S18-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G4
4 Membri
13 Guide realizzate
Un commento
I'm up based anyone know where I can get a replacement camera
Ashley Fall - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 3,371
