Salta al contenuto principale
Motorola Moto X Rear Facing Camera Flash Replacement
Cosa ti serve
  1. Motorola Moto X Rear Facing Camera Flash Replacement, SIM Card: passo 1, immagine 1 di 3 Motorola Moto X Rear Facing Camera Flash Replacement, SIM Card: passo 1, immagine 2 di 3 Motorola Moto X Rear Facing Camera Flash Replacement, SIM Card: passo 1, immagine 3 di 3
    • Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
    • Remove the SIM card tray.
    • If the SIM card does not fall free from the tray on its own, simply remove it with your fingers.
  2. Motorola Moto X Rear Facing Camera Flash Replacement, Back Cover Assembly: passo 2, immagine 1 di 3 Motorola Moto X Rear Facing Camera Flash Replacement, Back Cover Assembly: passo 2, immagine 2 di 3 Motorola Moto X Rear Facing Camera Flash Replacement, Back Cover Assembly: passo 2, immagine 3 di 3
    • In the following steps you will be releasing the clips holding the phone's cases together. However, the back case is also secured with an adhesive pad. After separating the clips you will use an iOpener to allow the case to fully open. Do not attempt to fully open the phone before loosening the adhesive.
    • Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
    • Slide the plastic opening tool along the seam toward the upper corner.
  3. Motorola Moto X Rear Facing Camera Flash Replacement: passo 3, immagine 1 di 2 Motorola Moto X Rear Facing Camera Flash Replacement: passo 3, immagine 2 di 2
    • Carefully slide the plastic opening tool around the corner, freeing it from clips.
  4. Motorola Moto X Rear Facing Camera Flash Replacement: passo 4, immagine 1 di 2 Motorola Moto X Rear Facing Camera Flash Replacement: passo 4, immagine 2 di 2
    • Pry around the top right corner of the phone between the two covers.
  5. Motorola Moto X Rear Facing Camera Flash Replacement: passo 5, immagine 1 di 3 Motorola Moto X Rear Facing Camera Flash Replacement: passo 5, immagine 2 di 3 Motorola Moto X Rear Facing Camera Flash Replacement: passo 5, immagine 3 di 3
    • Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on.
    • The plastic on the front cover is thinner near the buttons, and the buttons may move around. Go slowly to avoid damaging the buttons or the front cover.
    • Do not push the opening tool deep into phone, or you may damage internal components.
  6. Motorola Moto X Rear Facing Camera Flash Replacement: passo 6, immagine 1 di 1
    • Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
  7. Motorola Moto X Rear Facing Camera Flash Replacement: passo 7, immagine 1 di 3 Motorola Moto X Rear Facing Camera Flash Replacement: passo 7, immagine 2 di 3 Motorola Moto X Rear Facing Camera Flash Replacement: passo 7, immagine 3 di 3
    • Starting from the SIM slot side, carefully peel the back cover off of the phone.
    • The back cover is very flexible, but you don't want to damage any internal components by being too hasty.
    • There is a chance that the NFC coil may remain stubbornly adhered to the back cover. If that's the case, stop peeling the cover and reapply a heated iOpener to the back cover.
    • Do not separate the back cover entirely; it is still connected to the phone by the camera flash cable.
    • The flash cable is attached on the power/volume button side of the phone.
  8. Motorola Moto X Rear Facing Camera Flash Replacement: passo 8, immagine 1 di 1
    • Gently set the back cover down in a way that exposes the camera flash cable connector, but does not put strain on it.
  9. Motorola Moto X Rear Facing Camera Flash Replacement: passo 9, immagine 1 di 3 Motorola Moto X Rear Facing Camera Flash Replacement: passo 9, immagine 2 di 3 Motorola Moto X Rear Facing Camera Flash Replacement: passo 9, immagine 3 di 3
    • Use the tip of a spudger to flip up the retaining flap on the flash cable ZIF connector.
    • Be sure to pry only on the flap itself, not on the connector.
    • Pull the flash cable straight out of its socket.
  10. Motorola Moto X Rear Facing Camera Flash Replacement: passo 10, immagine 1 di 1
    • Separate the back cover from the phone.
  11. Motorola Moto X Rear Facing Camera Flash Replacement, Back Cover: passo 11, immagine 1 di 3 Motorola Moto X Rear Facing Camera Flash Replacement, Back Cover: passo 11, immagine 2 di 3 Motorola Moto X Rear Facing Camera Flash Replacement, Back Cover: passo 11, immagine 3 di 3
    • Use the flat end of a spudger to gently pry between the flash assembly and back cover to separate the adhesive.
    • Remove the flash assembly from the back cover.
    • You may also need to transfer the camera lens and the silicon pad from the rear case. These can be removed by prying carefully with a plastic opening tool.
    • Depending on the adhesive on the rear case, you may need to tape the flash assembly down to secure it.
Conclusione
Altre 2 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
458.731 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Community
141 Membri
17.746 Guide realizzate
Un commento
Where did you buy the flash flex replacement?? I cannot find it.
rmonsalves - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 4,295
