Introduzione
This is a fingerprint scanner replacement guide for the Motorola Moto G7 Play, specifically the XT1952-3 and XT1952-2. The fingerprint is an important feature for the device, as it helps provide extra security to keep files safe. If the device no longer unlocks when the sensor is touched, then it should be replaced.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Cosa ti serve
Remove the nine 3.2 mm screws from the motherboard cover with a Phillips #00 screwdriver.
Altre 3 persone hanno completato questa guida.
How long do you have to use the heat gun before the glue loosens?
Pamela DeMars - Replica
It's worked for me with about maybe 15-20 seconds of heating per side.
Matthieu Bister - Replica
I could not get the pick started under the cover. Ruined several tips. I started with a hair dryer and switched to a heat gun. Be careful with a heat gun! 😬
K Goatee - Replica
