The glass backplate needs to be removed first.
Heat along left edge of the backplate until the glass is almost too hot to touch.
Carefully insert razor blade in between glass back plate and frame of phone.
With glass lifted slightly, you can now insert a regular opening pick and remove the razor blade.
Work pick in further to slowly lift the glass away from the frame.
Slide pick to bottom of phone and insert a new pick on the left side
Slide pick along left edge towards the top of the phone.
Continue around right side of the backplate using the same procedure as Step 3 until the adhesive has been cut around the entire glass backplate.
Carefully remove backplate. It should come off fairly easily. If there is any resistance, heat that area and cut the adhesive again with opening pick.
Remove ten 3.2mm silver Phillips #000 screws
Remove one 3.8mm silver Phillips #000 screw
Remove five 2.7mm black phillips #000 screws
Using a plastic nylon spudger, carefully pry up on the battery connector to disconnect the battery.
Using a plastic spudger or prying tool, carefully lift the snap connectors attached to the Motherboard.
Lift the black antenna cable out from next to the vibrator motor so that it is loose from the frame.
Using a spudger, carefully lift the black lever of the zif connector (indicated by the arrow), then using tweezers, carefully pull the flex cable out of the connector.
Don't forget to eject the sim card tray like I almost did.
Carefully lift the motherboard out of the frame.
Once the upper part is free, pull the motherboard upwards and out, so that the charging port does not get stuck on the frame.
From this point, you can remove the battery and move what is needed to a new screen and frame assembly.
As you can see in the third picture, the home button cable in my new screen and frame assembly (from ebay) is in the wrong place. I had to just remove the lcd and from that point it was easier to just put the lcd on the old frame instead of reattaching it to the new frame. It wasn’t too hard. It was easier than removing the battery. Only hard part was putting fresh tesa tape on to hold the new screen.
Extremely disappointed! Purchased all the parts & tools this site said to get. Almost was excited that I’d be able to fix my daughters phone until I realized that the instructions on your site or horribly incomplete. That or assumptions are/were made that assume the person doing the repair has knowledge that I don’t have. Got all the way down to almost the end. No instructions on how to move the vibrator, ear speaker, antenna cable or flex cable to the new screen/digitizer (Item code: IF390-025-1). Videos on you tube show how to use the heat gun to separate the glass from the frame. But then you need liquid adhesive to reattach. No mention of having to do this & no mention of needing liquid adhesive. Ordered two of the Item code: IF390-025-1. One for my phone with a cracked screen. Obviously not going to try & fix mine since I’ll run into the same issue. Very disappointed.
Sorry, I made most of this guide myself when doing my first repair on the Moto G6. I was fixing it for a customer but decided to upload some pictures as I went to help out others. I actually haven’t had to repair another G6 so I haven’t had a chance to fix/complete this guide. It is marked as an incomplete guide.
I was just figuring it out as I went along. I ended up using the old frame so I didn’t remove the the vibrate motor, or ear speaker. Those two things are usually just glued in anyways. the only way to remove them is to carefully pry them out with very small, sturdy tweezers and spudgers. Be careful the speaker doesn’t separate. I’ve seen speakers in droids and Samsung phones separate when pried up. If half the speaker starts to come out without the rest, just push it back down and try to get the pry tool down farther. I just used Tesa Tape to hold the new screen in. No liquid glue. It might have helped though.
Honestly, some of the steps to repairing phones can only be learned through experience. Its hard to show everything. I’ve sure ripped a cable or two and broken a few back glass panels.
Or you can keep the battery in and only remove the LCD and digitizer from the frame.
This may be easier and cheaper than trying to swap the battery, but you will have to clean off the old adhesive and apply your own adhesive to hold down the new screen.
Altre 11 persone hanno completato questa guida.
