Salta al contenuto principale
Motorola Moto G5s Plus Display Replacement
Cosa ti serve
  1. Motorola Moto G5s Plus Display Replacement, Display: passo 1, immagine 1 di 3 Motorola Moto G5s Plus Display Replacement, Display: passo 1, immagine 2 di 3 Motorola Moto G5s Plus Display Replacement, Display: passo 1, immagine 3 di 3
    • Power off the phone before you begin.
    • Bring the heat gun one to two inches from the edges of the display to melt the display adhesive.
    • Spend equal amounts of time applying heat around the entire edge of the phone.
  2. Motorola Moto G5s Plus Display Replacement: passo 2, immagine 1 di 2 Motorola Moto G5s Plus Display Replacement: passo 2, immagine 2 di 2
    • Attach the suction cup to the display slightly to the left of center.
    • Exert a moderate force to pull on the suction cup. The display will come loose.
  3. Motorola Moto G5s Plus Display Replacement: passo 3, immagine 1 di 3 Motorola Moto G5s Plus Display Replacement: passo 3, immagine 2 di 3 Motorola Moto G5s Plus Display Replacement: passo 3, immagine 3 di 3
    • Insert the opening tool inside the loosened edge.
    • Gradually work the opening tool around the edge of the entire screen to cut through the adhesive.
    • Do not wedge the opening tool too far beneath the screen. Using too much force can result in torn connector cables.
  4. Motorola Moto G5s Plus Display Replacement: passo 4, immagine 1 di 3 Motorola Moto G5s Plus Display Replacement: passo 4, immagine 2 di 3 Motorola Moto G5s Plus Display Replacement: passo 4, immagine 3 di 3
    • The display should now be entirely loose, attached only by the connectors at the top of the device and the fingerprint sensor connector at the bottom of the device.
    • Press down on the fingerprint sensor with the display slightly raised to disconnect it from the display.
    • If the fingerprint sensor does not come loose, use the heat gun to loosen its adhesive.
  5. Motorola Moto G5s Plus Display Replacement: passo 5, immagine 1 di 2 Motorola Moto G5s Plus Display Replacement: passo 5, immagine 2 di 2
    • The cables at the top of the device are fragile. If you are using this guide as a prerequisite for replacing another part, be careful not to tear the cables while lifting the screen.
    • Remove the one 5mm Torx-5 screw located by the connector cables in the top right corner of the device.
  6. Motorola Moto G5s Plus Display Replacement: passo 6, immagine 1 di 2 Motorola Moto G5s Plus Display Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Grab the unscrewed metal plate with your blunt tweezers.
    • Slide the metal plate to the left and then out to remove it.
    • Removing the plate will expose the display assembly's connection to the phone's motherboard.
  7. Motorola Moto G5s Plus Display Replacement: passo 7, immagine 1 di 2 Motorola Moto G5s Plus Display Replacement: passo 7, immagine 2 di 2
    • Disengage the two cable connectors by gently prying beneath the edge of the connector with the opening tool.
  8. Motorola Moto G5s Plus Display Replacement: passo 8, immagine 1 di 2 Motorola Moto G5s Plus Display Replacement: passo 8, immagine 2 di 2
    • Lift up the detached right connector from its housing using blunt tweezers.
    • The housing has light adhesive underneath it. Use a small amount of force to remove the connector from the housing.
Conclusione
Altre 8 persone hanno completato questa guida.
Kevin George
Membro da: 10/08/18
1.099 Reputazione
4 Guide realizzate
Cal Poly, Team S4-G5, White Fall 2018 Membro di Cal Poly, Team S4-G5, White Fall 2018
CPSU-WHITE-F18S4G5
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 44
Tutti i Tempi: 4,794
