Salta al contenuto principale
Motorola Moto G5 Vibration Motor Replacement
Cosa ti serve
  1. Motorola Moto G5 Vibration Motor Replacement, Back Cover: passo 1, immagine 1 di 2 Motorola Moto G5 Vibration Motor Replacement, Back Cover: passo 1, immagine 2 di 2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Vibration Motor Replacement: passo 2, immagine 1 di 3 Motorola Moto G5 Vibration Motor Replacement: passo 2, immagine 2 di 3 Motorola Moto G5 Vibration Motor Replacement: passo 2, immagine 3 di 3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Vibration Motor Replacement: passo 3, immagine 1 di 3 Motorola Moto G5 Vibration Motor Replacement: passo 3, immagine 2 di 3 Motorola Moto G5 Vibration Motor Replacement: passo 3, immagine 3 di 3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Vibration Motor Replacement: passo 4, immagine 1 di 2 Motorola Moto G5 Vibration Motor Replacement: passo 4, immagine 2 di 2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Vibration Motor Replacement, Battery: passo 5, immagine 1 di 2 Motorola Moto G5 Vibration Motor Replacement, Battery: passo 5, immagine 2 di 2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Vibration Motor Replacement: passo 6, immagine 1 di 1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Vibration Motor Replacement, Vibration Motor: passo 7, immagine 1 di 1
    • Remove the nine (9) 4mm Philips screws securing the daughterboard cover.
  8. Motorola Moto G5 Vibration Motor Replacement: passo 8, immagine 1 di 1
    • Remove the plastic casing on the bottom of the phone by gently pulling.
  9. Motorola Moto G5 Vibration Motor Replacement: passo 9, immagine 1 di 3 Motorola Moto G5 Vibration Motor Replacement: passo 9, immagine 2 di 3 Motorola Moto G5 Vibration Motor Replacement: passo 9, immagine 3 di 3
    • Remove the three connectors on the board below the battery slow by gently pulling on the small gold tab with a pair of tweezers.
  10. Motorola Moto G5 Vibration Motor Replacement: passo 10, immagine 1 di 1
    • Remove the 3.4 mm Philips screw securing the daughterboard to the frame.
  11. Motorola Moto G5 Vibration Motor Replacement: passo 11, immagine 1 di 1
    • Use the point of a spudger to lift the vibration motor connector up out of the socket on the I/O board.
    • Be very careful to pry only on the connector under the red and black cables, not on the socket itself.
    Do not pull as shown o the picture!! Otherwise you will tear of the connector as well (actually as seen on the picture!!). You have to pull upwards so the vibration motor is unplugged an the socket stays attached to the board. If you do as shown on the picture you won't be able to reuse the charging board. Or at least I wouldn’t know how to re-attach a new vibration motor to the board as shown….
    I just replaced the usb charging socket/board since my Moto G5 stopped charging. In my case I did not need the board anymore, so I could have just pulled off the vibration motor as shown above. I suggest, however, to keep the socket for the vibration motor in place by simply pulling upwards.
    (But even if you broke the charging board - the replacement board cost me €10 ;-))
    Marko Stein - Replica
    The procedure has been updated!
    Oh boy that was very incorrect procedure! I cropped the image and changed the text to hopefully be more clear. Thanks for catching that!
    Sam Goldheart -
Conclusione
Altre 7 persone hanno completato questa guida.
Miles Cobb
Membro da: 01/24/18
370 Reputazione
1 Guida realizzata
Cal Poly, Team S2-G3, Livingston Winter 2018 Membro di Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
4 Membri
16 Guide realizzate
Un commento
Is this also where the mic is located?
Matt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 3,381
