Salta al contenuto principale
Motorola Moto G5 Vibration Motor Replacement
Cosa ti serve
  1. Motorola Moto G5 Vibration Motor Replacement, Back Cover: passo 1, immagine 1 di 2 Motorola Moto G5 Vibration Motor Replacement, Back Cover: passo 1, immagine 2 di 2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Vibration Motor Replacement: passo 2, immagine 1 di 3 Motorola Moto G5 Vibration Motor Replacement: passo 2, immagine 2 di 3 Motorola Moto G5 Vibration Motor Replacement: passo 2, immagine 3 di 3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Vibration Motor Replacement: passo 3, immagine 1 di 3 Motorola Moto G5 Vibration Motor Replacement: passo 3, immagine 2 di 3 Motorola Moto G5 Vibration Motor Replacement: passo 3, immagine 3 di 3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Vibration Motor Replacement: passo 4, immagine 1 di 2 Motorola Moto G5 Vibration Motor Replacement: passo 4, immagine 2 di 2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Vibration Motor Replacement, Battery: passo 5, immagine 1 di 2 Motorola Moto G5 Vibration Motor Replacement, Battery: passo 5, immagine 2 di 2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Vibration Motor Replacement: passo 6, immagine 1 di 1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Vibration Motor Replacement, Vibration Motor: passo 7, immagine 1 di 1
    • Remove the nine (9) 4mm Philips screws securing the daughterboard cover.
  8. Motorola Moto G5 Vibration Motor Replacement: passo 8, immagine 1 di 1
    • Remove the plastic casing on the bottom of the phone by gently pulling.
  9. Motorola Moto G5 Vibration Motor Replacement: passo 9, immagine 1 di 3 Motorola Moto G5 Vibration Motor Replacement: passo 9, immagine 2 di 3 Motorola Moto G5 Vibration Motor Replacement: passo 9, immagine 3 di 3
    • Remove the three connectors on the board below the battery slow by gently pulling on the small gold tab with a pair of tweezers.
  10. Motorola Moto G5 Vibration Motor Replacement: passo 10, immagine 1 di 1
    • Remove the 3.4 mm Philips screw securing the daughterboard to the frame.
  11. Motorola Moto G5 Vibration Motor Replacement: passo 11, immagine 1 di 1
    • Use the point of a spudger to lift the vibration motor connector up out of the socket on the I/O board.
    • Be very careful to pry only on the connector under the red and black cables, not on the socket itself.
Conclusione
Altre 7 persone hanno completato questa guida.
Miles Cobb
Membro da: 01/24/18
370 Reputazione
1 Guida realizzata
Cal Poly, Team S2-G3, Livingston Winter 2018 Membro di Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
4 Membri
16 Guide realizzate
Un commento
Is this also where the mic is located?
Matt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 3,298
