Salta al contenuto principale
Motorola Moto G5 Front Camera Replacement
Cosa ti serve
  1. Motorola Moto G5 Front Camera Replacement, Back Cover: passo 1, immagine 1 di 2 Motorola Moto G5 Front Camera Replacement, Back Cover: passo 1, immagine 2 di 2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Front Camera Replacement: passo 2, immagine 1 di 3 Motorola Moto G5 Front Camera Replacement: passo 2, immagine 2 di 3 Motorola Moto G5 Front Camera Replacement: passo 2, immagine 3 di 3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Front Camera Replacement: passo 3, immagine 1 di 3 Motorola Moto G5 Front Camera Replacement: passo 3, immagine 2 di 3 Motorola Moto G5 Front Camera Replacement: passo 3, immagine 3 di 3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Front Camera Replacement: passo 4, immagine 1 di 2 Motorola Moto G5 Front Camera Replacement: passo 4, immagine 2 di 2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Front Camera Replacement, Battery: passo 5, immagine 1 di 2 Motorola Moto G5 Front Camera Replacement, Battery: passo 5, immagine 2 di 2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Front Camera Replacement: passo 6, immagine 1 di 1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Front Camera Replacement, Rear Facing Camera: passo 7, immagine 1 di 2 Motorola Moto G5 Front Camera Replacement, Rear Facing Camera: passo 7, immagine 2 di 2
    • Remove the eight (8) 4mm screws with a Phillips screwdriver.
  8. Motorola Moto G5 Front Camera Replacement: passo 8, immagine 1 di 3 Motorola Moto G5 Front Camera Replacement: passo 8, immagine 2 di 3 Motorola Moto G5 Front Camera Replacement: passo 8, immagine 3 di 3
    • Pry the top motherboard cover off using a plastic opening tool.
    • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
  9. Motorola Moto G5 Front Camera Replacement: passo 9, immagine 1 di 3 Motorola Moto G5 Front Camera Replacement: passo 9, immagine 2 di 3 Motorola Moto G5 Front Camera Replacement: passo 9, immagine 3 di 3
    • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
  10. Motorola Moto G5 Front Camera Replacement, Motherboard: passo 10, immagine 1 di 1
    • Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
  11. Motorola Moto G5 Front Camera Replacement: passo 11, immagine 1 di 1
    • Lift the motherboard up from the top of the phone.
  12. Motorola Moto G5 Front Camera Replacement: passo 12, immagine 1 di 1
    • Unplug the back connector from the motherboard using tweezers.
  13. Motorola Moto G5 Front Camera Replacement, Front Camera: passo 13, immagine 1 di 2 Motorola Moto G5 Front Camera Replacement, Front Camera: passo 13, immagine 2 di 2
    • Grab the connector with the tweezers and gently unplug the front camera from the motherboard.
Conclusione
Altre 4 persone hanno completato questa guida.
Enosh Reeder
Membro da: 01/24/18
209 Reputazione
1 Guida realizzata
Cal Poly, Team S2-G3, Livingston Winter 2018 Membro di Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,943
