Salta al contenuto principale
Motorola Moto G4 Speaker Replacement
Cosa ti serve
  1. Motorola Moto G4 Speaker Replacement, Back Cover: passo 1, immagine 1 di 3 Motorola Moto G4 Speaker Replacement, Back Cover: passo 1, immagine 2 di 3 Motorola Moto G4 Speaker Replacement, Back Cover: passo 1, immagine 3 di 3
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Motorola Moto G4 Speaker Replacement: passo 2, immagine 1 di 2 Motorola Moto G4 Speaker Replacement: passo 2, immagine 2 di 2
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Motorola Moto G4 Speaker Replacement: passo 3, immagine 1 di 3 Motorola Moto G4 Speaker Replacement: passo 3, immagine 2 di 3 Motorola Moto G4 Speaker Replacement: passo 3, immagine 3 di 3
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Motorola Moto G4 Speaker Replacement: passo 4, immagine 1 di 2 Motorola Moto G4 Speaker Replacement: passo 4, immagine 2 di 2
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Motorola Moto G4 Speaker Replacement, Midframe: passo 5, immagine 1 di 3 Motorola Moto G4 Speaker Replacement, Midframe: passo 5, immagine 2 di 3 Motorola Moto G4 Speaker Replacement, Midframe: passo 5, immagine 3 di 3
    • Push to eject and remove the MicroSD and SIM cards (if installed).
  6. Motorola Moto G4 Speaker Replacement: passo 6, immagine 1 di 2 Motorola Moto G4 Speaker Replacement: passo 6, immagine 2 di 2
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  7. Motorola Moto G4 Speaker Replacement: passo 7, immagine 1 di 1
    • Remove the rubber cover.
  8. Motorola Moto G4 Speaker Replacement: passo 8, immagine 1 di 2 Motorola Moto G4 Speaker Replacement: passo 8, immagine 2 di 2
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  9. Motorola Moto G4 Speaker Replacement: passo 9, immagine 1 di 1
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
    In my kit, the T3 Torx bit came in the ‘repair part’ box, while a T5 Torx bit was in the ‘repair tools’ box.
    Joseph Albert - Replica
    my phone had t4, not t3
    Donald Smith - Replica
    Screws are stuck quite hard, apply a hefty amount of pressure when removing. Otherwise you’ll destroy the thread
    face - Replica
    unable to remove 8 of the screws. any suggestions?
    wayne malcom - Replica
    My T4 is the tool that fit. I can see why people strip these. They were dam tight for such little screws.
    I also had a tough time getting them out of the socket once loose. Magnet in the tool was not very strong. I used my tweezers, and scratch the screw heads. That means they are real soft steel, and strip easy.
    P 38 - Replica
  10. Motorola Moto G4 Speaker Replacement: passo 10, immagine 1 di 1
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
    I couldn’t get the spudger in, but had success with the opening pick instead.
    Bernd Mast - Replica
  11. Motorola Moto G4 Speaker Replacement: passo 11, immagine 1 di 1
    • Remove the midframe.
    During the midframe removal, be careful and do not put too much torsional stress on the loudspeaker pickup wires (to the right of the main camera). It’s not that difficult to crush or shear the pickups there. Doing so will render your phone silent.
    Kevin Kwan - Replica
    Exactly what happened to me. Both contacts broke off and if just loosely put where they were, they can't make proper contact anymore.
    There should be a warning about this in the guide itself!
    Simon Vetter -
  12. Motorola Moto G4 Speaker Replacement, Battery Disconnection: passo 12, immagine 1 di 2 Motorola Moto G4 Speaker Replacement, Battery Disconnection: passo 12, immagine 2 di 2
    • Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
    • Gently pry straight up to disconnect the battery.
    • Pry only from the side where the wires attach to the connector—if you pry anywhere else, you may break the socket.
    • During reassembly, align the connector in its socket and then press straight down to reconnect it, wiggling slightly as you press to help it seat correctly.
  13. Motorola Moto G4 Speaker Replacement, Speaker: passo 13, immagine 1 di 3 Motorola Moto G4 Speaker Replacement, Speaker: passo 13, immagine 2 di 3 Motorola Moto G4 Speaker Replacement, Speaker: passo 13, immagine 3 di 3
    • Strong adhesive secures the earpiece speaker. If necessary, apply heat or a few drops of isopropyl alcohol to help weaken the adhesive and make it easier to remove.
    • Pry up the speaker with a pry tool or a pair of tweezers. Be careful not to damage any surrounding components.
    • If you plan to re-use the speaker, be careful not to pry at it anywhere other than on its black plastic frame, as the speaker is easily damaged.
    • Check the condition of the adhesive around the bottom of the earpiece speaker when you reinstall it. A little heat from a hair dryer or iOpener can help soften the adhesive and make it sticky again.
    • The back of the speaker is magnetic. Be careful to not touch it to other parts of the motherboard.
    You should have clearly told us not to use the tweezers in such a way as to touch the bottom side of that speaker box. I accidentally touched the other side with my tweezer while removing which caused a hole in the thin metal membrane. Now my speaker works but has an incredible amount of distortion. You MUST put a warning for these things. Now I have to buy a new speaker module.
    Anu S - Replica
    On my Moto g4 plus I can't hear with ear piece speaker but I can hear with speaker phone mode, even after replacing with new speaker
    Dr.amol bhosale - Replica
    4 steps on how to remove the battery cover. Really? Anyone who has ever owned one of these would know how to pull it off. Why not just say 'remove back cover? Ridiculous.
    [deleted] - Replica
Conclusione
Altre 6 persone hanno completato questa guida.
Kierra Schau
Membro da: 09/28/17
1.511 Reputazione
4 Guide realizzate
USF Tampa, Team S11-G2, Passmore Fall 2017 Membro di USF Tampa, Team S11-G2, Passmore Fall 2017
USFT-PASSMORE-F17S11G2
3 Membri
13 Guide realizzate
4 Commenti
i have problem with speaker. no sound. tried direct connecting external speaker . still no sound. so seems like its not sending signal. i checked all the settings
SHAIK Rahman - Replica
The warning should have told us to touch only the plastic black parts with the pointy end of the tweezers
Anu S - Replica
will use on my other phone, people can hear me, I can’t hear them after a drop. Now I know how to check the phone speaker. Thanks
gabriel johnson - Replica
Is it essential to disconnect the battery? Or is that more safety protocol?
Andy Morley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 23
Tutti i Tempi: 9,116
