Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Click here for an updated version of this guide. The version you are viewing is retained for historical purposes.
In this guide we will be removing and replacing the motherboard, which is the main source for all the other guides.
  1. Use the plastic opening tool to open the back cover as shown in the photo. Use the plastic opening tool to open the back cover as shown in the photo.
    • Use the plastic opening tool to open the back cover as shown in the photo.
  2. Heat an iOpener in the microwave for 30 seconds.
    • Heat an iOpener in the microwave for 30 seconds.
    • Place the heated iOpener on all four edges of the screen for approximately 2 minutes.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Apply the plastic opening tool on the edge of the screen near the front camera.
    • Apply the plastic opening tool on the edge of the screen near the front camera.
    • After creating enough space, allow the opening tool to be inserted on the side of the phone.
    • Create another space on the other side of the screen.
    • Leave the opening tool inserted.
    • Carefully apply the larger plastic opening tool by sliding it through the longer edge of the screen.
  5. A strip will be attached to the motherboard as shown. Using tweezers, carefully detach the strip from the motherboard. Using tweezers, carefully detach the strip from the motherboard.
    • A strip will be attached to the motherboard as shown.
    • Using tweezers, carefully detach the strip from the motherboard.
  6. With a T4 screwdriver, remove the10 "yellow" 2mm screws and 4 "black" 2mm screws. With a T4 screwdriver, remove the10 "yellow" 2mm screws and 4 "black" 2mm screws. With a T4 screwdriver, remove the10 "yellow" 2mm screws and 4 "black" 2mm screws.
    • With a T4 screwdriver, remove the10 "yellow" 2mm screws and 4 "black" 2mm screws.
  7. Use the metal spudger and lift the back cover on the bottom side of the phone (this is attached to the motherboard). Remove the motherboard from the device.
    • Use the metal spudger and lift the back cover on the bottom side of the phone (this is attached to the motherboard).
    • Remove the motherboard from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Irkan Notta
Membro da: 19/03/2018
1.034 Reputazione
7 Guide realizzate
Baylor, Team S5-G3, Williams Spring 2018 Membro di Baylor, Team S5-G3, Williams Spring 2018
BU-WILLIAMS-S18S5G3
3 Membri
8 Guide realizzate
i broke my battery connectig port where we plug in the battery. What should i do?
PLZ answer
All you need to Know (SAMMY) - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 463
