Salta al contenuto principale
Motorola Moto G Stylus 4G (2023) Charging Port Replacement
Cosa ti serve
  1. Motorola Moto G Stylus 4G (2023) Charging Port Replacement, Battery: passo 1, immagine 1 di 2 Motorola Moto G Stylus 4G (2023) Charging Port Replacement, Battery: passo 1, immagine 2 di 2
    • Insert an opening pick under the edge of the case and slide it around the edges.
    • Separate the back panel from the rest of the phone.
  2. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 2, immagine 1 di 1
    • Remove the seven 4 mm screws from the phone’s top with a Torx T5 screwdriver.
  3. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 3, immagine 1 di 2 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 3, immagine 2 di 2
    • Use the opening pick along the edges to separate the camera lens glass from the board.
  4. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 4, immagine 1 di 1
    • Remove three 4 mm screws with a Torx T5 screwdriver.
  5. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 5, immagine 1 di 1
    • Pry off the top perimeter with an ESD-safe spudger and set it aside.
  6. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 6, immagine 1 di 2 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 6, immagine 2 di 2
    • Pull the black tab off of the battery gently with your hand.
  7. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 7, immagine 1 di 2 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 7, immagine 2 di 2
    • Disconnect the four cables by inserting the opening pick beneath the edge of each.
  8. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 8, immagine 1 di 2 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 8, immagine 2 di 2
    • Together with the opening pick and an ESD-safe spudger, remove the old battery.
  9. Motorola Moto G Stylus 4G (2023) Charging Port Replacement, Ringer Speaker: passo 9, immagine 1 di 1
    • Remove seven 4 mm screws with the T5 Torx screwdriver.
  10. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 10, immagine 1 di 2 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 10, immagine 2 di 2
    • Remove the speaker using an ESD-safe spudger.
  11. Motorola Moto G Stylus 4G (2023) Charging Port Replacement, Charging Port: passo 11, immagine 1 di 1
    • Unplug the two antenna heads and main ribbon connector cable from the charging port board.
  12. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: passo 12, immagine 1 di 1
    • Pull the faulty charging port from the device body.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 81
