Salta al contenuto principale
Motorola Moto G Stylus (2021) Charging Port Replacement
Cosa ti serve
  1. Motorola Moto G Stylus (2021) Charging Port Replacement, Rear Case: passo 1, immagine 1 di 3 Motorola Moto G Stylus (2021) Charging Port Replacement, Rear Case: passo 1, immagine 2 di 3 Motorola Moto G Stylus (2021) Charging Port Replacement, Rear Case: passo 1, immagine 3 di 3
    • Push a SIM tray ejector into the hole.
    • Remove the SIM card and tray.
  2. Motorola Moto G Stylus (2021) Charging Port Replacement: passo 2, immagine 1 di 2 Motorola Moto G Stylus (2021) Charging Port Replacement: passo 2, immagine 2 di 2
    • Before you begin, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your phone and disconnect the charger and any peripheries before beginning disassembly.
    • Lay the phone face down.
    • Heat an iOpener and apply it to the rear case.
    • Alternatively, use a hair dryer to heat the rear case until it's almost too hot to touch.
  3. Motorola Moto G Stylus (2021) Charging Port Replacement: passo 3, immagine 1 di 2 Motorola Moto G Stylus (2021) Charging Port Replacement: passo 3, immagine 2 di 2
    • Insert an opening tool into the seam between the rear case and chassis.
    • Once you create a gap, insert an opening pick a couple of millimeters into the gap.
    • Slide the opening pick around the entire perimeter to sever the adhesive that secures the rear case.
    • If you feel excessive resistance, reheat the problem area(s).
    • Remove the rear case.
  4. Motorola Moto G Stylus (2021) Charging Port Replacement, Charging Port: passo 4, immagine 1 di 3 Motorola Moto G Stylus (2021) Charging Port Replacement, Charging Port: passo 4, immagine 2 di 3 Motorola Moto G Stylus (2021) Charging Port Replacement, Charging Port: passo 4, immagine 3 di 3
    • You may need to use your heating device again to remove glue from covering the screws.
    • Use a T4 Torx screwdriver to remove all seven 3.2 mm screws securing the black bracket.
  5. Motorola Moto G Stylus (2021) Charging Port Replacement: passo 5, immagine 1 di 2 Motorola Moto G Stylus (2021) Charging Port Replacement: passo 5, immagine 2 di 2
    • Use an opening tool to lift and remove the black bracket.
  6. Motorola Moto G Stylus (2021) Charging Port Replacement: passo 6, immagine 1 di 3 Motorola Moto G Stylus (2021) Charging Port Replacement: passo 6, immagine 2 di 3 Motorola Moto G Stylus (2021) Charging Port Replacement: passo 6, immagine 3 di 3
    • Use an opening tool to lift and disconnect the two antenna cables.
  7. Motorola Moto G Stylus (2021) Charging Port Replacement: passo 7, immagine 1 di 2 Motorola Moto G Stylus (2021) Charging Port Replacement: passo 7, immagine 2 di 2
    • Use an opening tool to lift and disconnect the press connector.
  8. Motorola Moto G Stylus (2021) Charging Port Replacement: passo 8, immagine 1 di 2 Motorola Moto G Stylus (2021) Charging Port Replacement: passo 8, immagine 2 di 2
    • Use a T4 Torx screwdriver to remove the 3 mm screw that secures the charging port.
  9. Motorola Moto G Stylus (2021) Charging Port Replacement: passo 9, immagine 1 di 2 Motorola Moto G Stylus (2021) Charging Port Replacement: passo 9, immagine 2 di 2
    • Carefully grab the charging port and slightly tilt it upwards.
    • This will allow it to be pulled outwards without bumping into the battery.
    • The cable might get in the way. If it does, carefully fold it upwards and out of the way. To prevent damaging it, do not force the cable to move in any direction. It should be able to be bent upwards with minimal force.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 37
Tutti i Tempi: 112
