Salta al contenuto principale
Motorola Moto G Power (2020) Charging Port Replacement
Cosa ti serve
  1. Motorola Moto G Power (2020) Charging Port Replacement, Back Case: passo 1, immagine 1 di 1
    • Position a suction cup securely on the back panel of the device.
    • Insert the opening pick into both sides of the phone and carefully slide it along to open the back panel of the device.
    • Do not fully remove the back panel; disconnect the fingerprint sensor first.
  2. Motorola Moto G Power (2020) Charging Port Replacement: passo 2, immagine 1 di 1
    • Apply gentle pressure to the fingerprint sensor with your finger to detach it from the back panel.
    • You may need to apply firm pressure to remove the circular sensor from the panel.
  3. Motorola Moto G Power (2020) Charging Port Replacement: passo 3, immagine 1 di 1
    • Fully remove the back panel from the device.
  4. Motorola Moto G Power (2020) Charging Port Replacement, Charging Port: passo 4, immagine 1 di 1
    • Using the tool T3 Torx screwdriver user must carefully remove 3 1.8mm screws helping to secure the part.
  5. Motorola Moto G Power (2020) Charging Port Replacement: passo 5, immagine 1 di 2 Motorola Moto G Power (2020) Charging Port Replacement: passo 5, immagine 2 di 2
    • In order to not damage the devices components slowly lift the bottom cover using a needed tool the spudger.
  6. Motorola Moto G Power (2020) Charging Port Replacement: passo 6, immagine 1 di 2 Motorola Moto G Power (2020) Charging Port Replacement: passo 6, immagine 2 di 2
    • Carefully pry the metal connectors that are attached to the cables with the sudger
    • secondly, on the right side of the device slowly disconnect the two cables from the charge port.
    • Cables are color coded one white wire and one black wire
  7. Motorola Moto G Power (2020) Charging Port Replacement: passo 7, immagine 1 di 2 Motorola Moto G Power (2020) Charging Port Replacement: passo 7, immagine 2 di 2
    • Using a spudger carefully raise the charging port out of your device
    • Light pressure needed to loosen the adhesive
    • Avoid using excessive force to prevent component damge
  8. Motorola Moto G Power (2020) Charging Port Replacement: passo 8, immagine 1 di 1
    • Gently slide the charging port of the device while avoiding component damage.
Conclusione
Altre 7 persone hanno completato questa guida.
Harry Jung
Membro da: 06/23/22
757 Reputazione
4 Guide realizzate
3 Commenti
This guide is good, but understates the ease of taking the back off. There is adhesive holding it on, and it took a heat gun and a LOT of force to pry it open. I only found out when I was trying to tell which of the two shell grooves I needed to pry open (the back one, since there's no side view) and found a different guide on Youtube, and saw them using a heating pad. I also couldn't tell WHICH 3 screws of the 5 were necessary to remove, so I just did all 5. Some circling would help!
Outside of that, thank you so much for the guide, I fixed my first phone all by my self! Minus borrowing my dad's heat gun and the two of us working together to pry the case open, seriously that was the hardest part. Once the case is open, the rest is EASY!! Now to get the dang case back on...
Auxome Von Socks - Replica
You did not show how to connect the broken charger port do u soder it in or what I'm looking into this
david dempsey - Replica
Is the OEM charging port board REV_A or REV_B type? Most available replacement parts I see are REV_B type, but I also see comments about audio output and cellular antenna problems with this type.
Jacob Perkins - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 57
Tutti i Tempi: 3,603
