Salta al contenuto principale
Motorola Moto G Power (2020) Charging Port Replacement
Cosa ti serve
  1. Motorola Moto G Power (2020) Charging Port Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place a suction cup on the back of the device.
    • Then open up the back of the device by sliding the opening pick into both sides of the phone.
    • Do not remove the back panel completely; you must disconnect the fingerprint sensor first.
  2. Motorola Moto G Power (2020) Charging Port Replacement: passo 2, immagine 1 di 1
    • Put pressure on the fingerprint sensor with your finger to detach it from the back panel.
    • You may have to use significant force to get the circular sensor off the panel.
  3. Motorola Moto G Power (2020) Charging Port Replacement: passo 3, immagine 1 di 1
    • Completely remove the back panel from the device.
  4. Motorola Moto G Power (2020) Charging Port Replacement, Charging Port: passo 4, immagine 1 di 1
    • Remove three 1.8 mm screws using a T3 Torx screwdriver.
  5. Motorola Moto G Power (2020) Charging Port Replacement: passo 5, immagine 1 di 2 Motorola Moto G Power (2020) Charging Port Replacement: passo 5, immagine 2 di 2
    • Lift the bottom cover of the device using the spudger.
  6. Motorola Moto G Power (2020) Charging Port Replacement: passo 6, immagine 1 di 2 Motorola Moto G Power (2020) Charging Port Replacement: passo 6, immagine 2 di 2
    • Use the spudger to lift the metal connection.
    • Disconnect the cables located on the right side of the device from the charging port.
    • There should one white wire and one black wire.
  7. Motorola Moto G Power (2020) Charging Port Replacement: passo 7, immagine 1 di 2 Motorola Moto G Power (2020) Charging Port Replacement: passo 7, immagine 2 di 2
    • Use a spudger to lift the charging port out of the device.
    • You may have to use some force to get the adhesive loose.
    • DO NOT use excessive force.
  8. Motorola Moto G Power (2020) Charging Port Replacement: passo 8, immagine 1 di 1
    • Grab the charging port, then slide it out of the device.
Conclusione
Altre 6 persone hanno completato questa guida.
Harry Jung
Membro da: 06/23/22
736 Reputazione
4 Guide realizzate
2 Commenti
This guide is good, but understates the ease of taking the back off. There is adhesive holding it on, and it took a heat gun and a LOT of force to pry it open. I only found out when I was trying to tell which of the two shell grooves I needed to pry open (the back one, since there's no side view) and found a different guide on Youtube, and saw them using a heating pad. I also couldn't tell WHICH 3 screws of the 5 were necessary to remove, so I just did all 5. Some circling would help!
Outside of that, thank you so much for the guide, I fixed my first phone all by my self! Minus borrowing my dad's heat gun and the two of us working together to pry the case open, seriously that was the hardest part. Once the case is open, the rest is EASY!! Now to get the dang case back on...
Auxome Von Socks - Replica
You did not show how to connect the broken charger port do u soder it in or what I'm looking into this
david dempsey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 121
Tutti i Tempi: 3,114
