Introduzione
This guide will show you how to replace the SIM/SD card reader of your Motorola Moto G 3rd Generation. Replacing this part requires disassembling much of the phone.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Cosa ti serve
Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
Evenly apply heat to the edges of the touchscreen to loosen the adhesive. Continue to Step 3 once the edge of the screen is warm to the touch.
I kept my phone on the radiator for 10min and loosened it enough to open (felt safer than a heat gun).
As the adhesive loosens, pry up an edge of the screen with a plastic opening tool or an opening pick. A suction cup may also be useful here.
Use an opening pick to hold that edge in place and continue this process around the entire screen, applying more heat as necessary.
What width of adhesive is appropriate to buy to replace the existing one? I can see 1mm, 2mm etc for sale
The width of the adhesive tape that goes around the rim is 2mm. But rather than buying generic 2mm tape, which won't seal well at the corners because it would be bent pretty sharply, it's best to get a precut adhesive that is made for this specific phone and that comes with the corners (and everything else) already pre-shaped: it's cut into a phone-shaped sheet, most of which you'll be discarding. Such sheets are available on ebay.
Attrezzo utilizzato in questo passaggio:Tesa 61395 Tape$5.99
Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
Pull the display cable from its socket on the motherboard.
This part was actually the trickiest of the whole (replacing battery) process. Putting it back together here is tough… well would have been better had I not left my glasses in work.
[English below]
Wer das Gerät während des Displaywechsels eingeschaltet lässt, sollte es dennoch einmal neustarten, wenn es fest verklebt wurde. Wie ich auf die harte Tour herausfand, kalibriert sich der Annäherungssensor erst bei einem Neustart neu und geht nach einem Wechsel (Display abgenommen = niedrigerer Wert) davon aus, dass das Handy dauerhaft in der Tasche/am Ohr ist.
Ein kurzer Neustart verschafft Abhilfe.
[English]
For those not powering off the device while changing the display (i.e. to test the functionality) I recommend to restart the device after the repair is done and the display is glued in.
As I found out the hard way, the proximity sensor recalibrates at the restart and without the display it sets lower values as a minimum (since there are no obstacles in the way). After the display change it will think that the phone is in your pocket or at your ear all the time.
A restart solves that problem.
I am using a Moto G3 phone as my backup phone and it’s screen is cracked but it is working fine. After watching your video I removed the screen carefully, bought a new digitized screen and fixed it. Now I am in a big trouble because the touch pad doesn't work. Even I couldn't switch off it. I complained the seller and he gave me another screen thinking the previous is having an issue. Unfortunately after fixing it the problem remains. How to solve the touch pad issue please?
I agree this is extremely tough, to take off or put on. Taking it off is hard enough ( the lever is tiny and opens up). Connecting it back up is tough because the position is so awkward.
Remove the ten 2.4 mm T4 screws from the sides of the motherboard.
Remove the four 4.5 mm T4 screws from the top and bottom of the motherboard.
Can you telll motherboard price and like plzzz
These are T5 screws
They were all T4 for me.
If adhesive residue is holding the motherboard in place, use a Jimmy to cut the adhesive between the motherboard and the back of the phone.
Carefully lift the right edge of the motherboard from the phone.
When taken battery out I took it out wrong and now the new battery plugging into old area is not possible is there a repair part where the battery connects to the logic board Mahalo.
Use a plastic opening tool to disconnect the battery wires from the motherboard.
troquei a bateria e o cellular não liga mais..
Replacing this battery connection is the single hardest connection I have done on any phone or laptop in my experience! The border walls break very easily and the connection itself breaks off the board very easily. I am still not sure how to slide the plug into place without breaking off a border wall.
Yup, this is where it ended for me. I appears some connectors broke of (I’d say 1/2 mm by 1/2mm small) which I have nor tools nor knowledge to repair. I did have to use some force to get break the connection but I think I was well within margins. (This was the first phone I tried to repair however)
Remove the three 2.4 mm T4 screws from the right side and bottom of the SIM/SD card panel.
Altre 25 persone hanno completato questa guida.
6 Commenti
I replace with new SIM card reader gotten from China, but not working.
bhai china ka mal to aisa hi milega
Any further solution to this.
Ha abhi le ke aata hu
My sim card is working but during calling ,sim network down.plz help me
This repair is much, much more difficult than it appears. The LCD connection and the battery connection are borderline impossible. Everything else is simple or nearly simple. The glue is about a tenth as tough as Samsung phones.
Thomas Hayes - Replica
