Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide shows you how to replace the rear camera in a Motorola Moto G 2nd Generation smartphone.
Parti
Nessuna parte specificata.
  1. Remove back cover. Remove back cover.
    • Remove back cover.
  2. Remove back frame. The screws feature different sizes and lengths, so keep them in order after removing them. Remove back frame. The screws feature different sizes and lengths, so keep them in order after removing them. Remove back frame. The screws feature different sizes and lengths, so keep them in order after removing them.
    • Remove back frame. The screws feature different sizes and lengths, so keep them in order after removing them.
  3. Release SIM&SD card reader assembly connector, battery connector and vibrator at first. Release SIM&SD card reader assembly connector, battery connector and vibrator at first. Release SIM&SD card reader assembly connector, battery connector and vibrator at first.
    • Release SIM&SD card reader assembly connector, battery connector and vibrator at first.
  4. Loosen kinds of sticker under the battery and remove it with card reader assembly together. Loosen kinds of sticker under the battery and remove it with card reader assembly together. Loosen kinds of sticker under the battery and remove it with card reader assembly together.
    • Loosen kinds of sticker under the battery and remove it with card reader assembly together.
  5. Release LCD screen connector. Release LCD screen connector. Release LCD screen connector.
    • Release LCD screen connector.
  6. Release front camera connector and sensor connector. Release front camera connector and sensor connector.
    • Release front camera connector and sensor connector.
  7. Remove three screws on the motherboard and take away the motherboard. Remove three screws on the motherboard and take away the motherboard.
    • Remove three screws on the motherboard and take away the motherboard.
  8. Remove the rear camera from motherboard. Remove the rear camera from motherboard. Remove the rear camera from motherboard.
    • Remove the rear camera from motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Sophia
Membro da: 25/03/2014
43.261 Reputazione
62 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,955
