Introduzione
Follow this guide, and you will be able to replace the front camera in your Moto G, in the event that it breaks or malfunctions. The part itself is simple to remove, but getting to it make take some time and care. You will need a T5 Torx screwdriver and a plastic opening tool.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Cosa ti serve
Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
Work your way down the sides to avoid cracking the rear cover.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Using a plastic opening tool or tweezers, disconnect the SIM/SD card reader at the top of the phone.
Disconnect the battery connector by prying it off of the motherboard.
Disconnect the vibration motor by prying its connector off of the motherboard.
Use the prying tweezers to remove the front facing camera.
Altre 9 persone hanno completato questa guida.
