Salta al contenuto principale
Motorola Moto E6 Rear Facing Camera Replacement
Cosa ti serve
  1. Motorola Moto E6 Rear Facing Camera Replacement, Back Cover: passo 1, immagine 1 di 2 Motorola Moto E6 Rear Facing Camera Replacement, Back Cover: passo 1, immagine 2 di 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Rear Facing Camera Replacement, Battery: passo 2, immagine 1 di 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Rear Facing Camera Replacement, Motherboard: passo 3, immagine 1 di 1
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Rear Facing Camera Replacement: passo 4, immagine 1 di 1
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Rear Facing Camera Replacement: passo 5, immagine 1 di 1
    • Remove the two 1.1 mm T4 Torx screws from the bottom left and top right sides of the motherboard.
  6. Motorola Moto E6 Rear Facing Camera Replacement: passo 6, immagine 1 di 1
    • Remove the two press fit cables at the bottom of the motherboard with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
    • After removing the cables, remove the motherboard from the phone by hand.
  7. Motorola Moto E6 Rear Facing Camera Replacement, Rear Facing Camera: passo 7, immagine 1 di 1
    • Remove the press fit cable using the plastic opening tool, and remove the camera from the phone.
Conclusione
Cal Poly, Team S2-G3, White Winter 2020 Membro di Cal Poly, Team S2-G3, White Winter 2020
CPSU-WHITE-W20S2G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 602
