Introduzione
The Motorola Moto E6 Play phone has a 5.5” HD+ screen, with a Max Vision display (18:9 aspect ratio), 295 ppi, and IPS LCD feature. The screen is probably the most easily breakable part on the phone, but unfortunately it takes some effort to replace it. Before beginning this guide, be sure to power off the phone completely. This guide will also involve removing most of the other components of the phone, so warnings about swollen batteries should be considered for safety.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Cosa ti serve
Run the halberd spudger along the edges of the device. The back cover should easily pop off.
To remove the cover on the motherboard, remove the 10 silver 3.90 mm Phillips screws attaching the cover to the board using the Phillips #0 screwdriver.
With the angled tweezers, remove the black cover to reveal the motherboard underneath.
Use the angled tweezers to pry off the metal head of the connecting piece from the motherboard assembly.
Altre 4 persone hanno completato questa guida.
Un commento
I have done all steps here and removed screen. Now added new screen and put back together. However now the touchscreen completely doesnt work when you touch it. It starts up and screen looks amazing and shows images well but the touch aspect doesnt work. Any ideas?
