Salta al contenuto principale
Motorola Moto E6 Charging Dock Replacement
Cosa ti serve
  1. Motorola Moto E6 Charging Dock Replacement, Back Cover: passo 1, immagine 1 di 2 Motorola Moto E6 Charging Dock Replacement, Back Cover: passo 1, immagine 2 di 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Charging Dock Replacement, Battery: passo 2, immagine 1 di 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Charging Dock Replacement, Charging Dock: passo 3, immagine 1 di 1
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  4. Motorola Moto E6 Charging Dock Replacement: passo 4, immagine 1 di 1
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  5. Motorola Moto E6 Charging Dock Replacement: passo 5, immagine 1 di 1
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
  6. Motorola Moto E6 Charging Dock Replacement: passo 6, immagine 1 di 1
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team S2-G3, White Winter 2020 Membro di Cal Poly, Team S2-G3, White Winter 2020
CPSU-WHITE-W20S2G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,896
