Introduzione
Use this guide to replace a worn-out battery in the Motorola Moto E5. If your battery is swollen, take appropriate precautions.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
For your safety, discharge your existing battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Replacing the back cover adhesive after your repair is optional. If you choose to replace it, you’ll need to purchase pre-cut double-side tape.
Cosa ti serve
Prepare an iOpener and heat the back of the phone along one edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the back cover to the phone.
Apply a suction handle to the back cover, near the middle of the edge you heated up.
Pull the suction cup with firm, constant pressure to create a slight gap between the phone's frame and the back cover.
Insert an opening pick into the gap.
….and how deeply, do I insert this opening pick into the phone ? a quarter inch, 16th? eight they're ought to be specifics for this type of performance on this repair. No?
For this phone, there are no cables near the perimeter, so you can insert the pick as deeply as you desire. If there are fragile cables that can be damaged near the perimeter, our guides will state how deep you can insert the pick (example).
Attrezzo utilizzato in questo passaggio:Plastic Cards$2.99
If the adhesive strips broke and you can no longer access them, insert a plastic card in between the bottom of the battery and the phone's frame.
Carefully push the card down and inward to wedge it underneath the battery and pry it up.
Repair didn’t go as planned? Check out our Motorola Moto E5 Answers community for troubleshooting help.
Altre 3 persone hanno completato questa guida.
3 Commenti
отлично! долго не хотел его делать без инструкции.
For step #14, I had 15 screws on my midframe as it covered the entire bottom of the phone and didn’t taper down like yours did. Otherwise, the guide was great with no surprises, thanks.
Danke für die gute Anleitung. Zwar mußte ich einiges am Anfang anders machen, da der Akku schon hie Rückwand aufgesprengt hatte. Aber es hat sich gelohnt.
Anzumerken sei nur, das beim Werkzeug eine kleine selbsthaltende Pinzette günstig währe. Ich hatte eine solche in meinem Bestand und die hat mir beim Zusammenbau gut geholfen.
Mal sehen ob das Handy nach dem Akkuschaden wieder voll funktioniert.
Danke allen die so eine gute Beschreibung geliefert haben.
So what is the temperature Fahrenheit or Celsius that is too hot for the battery? There must be a maximum degree temp. in place… wouldn't you think? please speak/txt. in specific terms. That would be a great help. thank you
m. callo - Replica
Hello! When you heat the device with the iOpener, the iOpener is designed to never get hot enough to damage the battery. Anything above 200°F is too hot for a lithium-ion battery and will heavily damage it in a very short amount of time. You can often set the phone on a heat pad at 170°F (~80°C) for a few minutes without issue.
Arthur Shi -
