Salta al contenuto principale
Motorola Moto E4 Plus Rear Camera Replacement
Cosa ti serve
  1. Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: passo 1, immagine 1 di 3 Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: passo 1, immagine 2 di 3 Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: passo 1, immagine 3 di 3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Rear Camera Replacement: passo 2, immagine 1 di 2 Motorola Moto E4 Plus Rear Camera Replacement: passo 2, immagine 2 di 2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Rear Camera Replacement, Midframe: passo 3, immagine 1 di 1
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus Rear Camera Replacement: passo 4, immagine 1 di 2 Motorola Moto E4 Plus Rear Camera Replacement: passo 4, immagine 2 di 2
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus Rear Camera Replacement: passo 5, immagine 1 di 3 Motorola Moto E4 Plus Rear Camera Replacement: passo 5, immagine 2 di 3 Motorola Moto E4 Plus Rear Camera Replacement: passo 5, immagine 3 di 3
    • Remove the battery cover.
    Hoe kom ik aan een nieuwe cover of waar is die te koop.
    Antoinet - Replica
  6. Motorola Moto E4 Plus Rear Camera Replacement: passo 6, immagine 1 di 2 Motorola Moto E4 Plus Rear Camera Replacement: passo 6, immagine 2 di 2
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus Rear Camera Replacement: passo 7, immagine 1 di 2 Motorola Moto E4 Plus Rear Camera Replacement: passo 7, immagine 2 di 2
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus Rear Camera Replacement: passo 8, immagine 1 di 2 Motorola Moto E4 Plus Rear Camera Replacement: passo 8, immagine 2 di 2
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus Rear Camera Replacement, Battery Disconnect: passo 9, immagine 1 di 2 Motorola Moto E4 Plus Rear Camera Replacement, Battery Disconnect: passo 9, immagine 2 di 2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus Rear Camera Replacement, Rear Camera: passo 10, immagine 1 di 2 Motorola Moto E4 Plus Rear Camera Replacement, Rear Camera: passo 10, immagine 2 di 2
    • Use a pair of tweezers to peel up the copper tape that covers the rear camera flex connector.
    • Fold the copper tape out of the way.
  11. Motorola Moto E4 Plus Rear Camera Replacement: passo 11, immagine 1 di 2 Motorola Moto E4 Plus Rear Camera Replacement: passo 11, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the rear camera flex cable.
  12. Motorola Moto E4 Plus Rear Camera Replacement: passo 12, immagine 1 di 1
    • Carefully remove the rear camera with a pair of tweezers.
Conclusione
If possible, turn on your phone and test your repair before reassembly.
Altre 5 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
Un commento
I want Moto e 4 + camera
Mubbu N - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,544
