Introduzione
Use this guide to remove the power and volume buttons in the Motorola Moto E4 Plus (XT1771).
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Before disassembling your phone, discharge the battery below 25%. If your battery is swollen, do not heat your phone. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
Cosa ti serve
Insert the edge of the spudger into the notch on the bottom right corner of the phone.
Twist the spudger to start releasing the back cover from the phone.
Slide the spudger along the bottom edge to separate the back cover from the phone.
Remove the eighteen 3.3Â mm Phillips screws securing the midframe assembly.
Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
Use the edge of a spudger to open the lever of the ZIF connector.
Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
If possible, turn on your phone and test your repair before reassembling the device.
