Salta al contenuto principale
Motorola Moto E4 Plus Power and Volume Buttons Replacement
Cosa ti serve
  1. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Remove the back cover: passo 1, immagine 1 di 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Remove the back cover: passo 1, immagine 2 di 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Remove the back cover: passo 1, immagine 3 di 3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 2, immagine 1 di 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 2, immagine 2 di 2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Midframe: passo 3, immagine 1 di 1
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 4, immagine 1 di 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 4, immagine 2 di 2
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 5, immagine 1 di 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 5, immagine 2 di 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 5, immagine 3 di 3
    • Remove the battery cover.
  6. Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 6, immagine 1 di 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 6, immagine 2 di 2
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 7, immagine 1 di 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 7, immagine 2 di 2
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 8, immagine 1 di 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 8, immagine 2 di 2
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Battery Disconnect: passo 9, immagine 1 di 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Battery Disconnect: passo 9, immagine 2 di 2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Power & Volume Button: passo 10, immagine 1 di 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Power & Volume Button: passo 10, immagine 2 di 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Power & Volume Button: passo 10, immagine 3 di 3
    • Use the edge of a spudger to open the lever of the ZIF connector.
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
  11. Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 11, immagine 1 di 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 11, immagine 2 di 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement: passo 11, immagine 3 di 3
    • Use a pair of tweezers to gently peel the power and volume button unit out of its thin recess in the side of the frame.
    • Remove the power and volume button unit.
Conclusione
If possible, turn on your phone and test your repair before reassembling the device.
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 778
