Introduzione
If there is any problem with the phone that you plan to repair, removing the battery is the first step in completing the repairs and is critical for safety while working on the phone.
If your battery is swollen, take appropriate precautions.
  1. Insert the spudger into the notch on the corner of the phone and lift up to remove the back case. Insert the spudger into the notch on the corner of the phone and lift up to remove the back case.
    • Insert the spudger into the notch on the corner of the phone and lift up to remove the back case.
  2. Use the T4 Torx Screwdriver to remove the 17 3.2 mm screws in the back panel covering the battery.
    • Use the T4 Torx Screwdriver to remove the 17 3.2 mm screws in the back panel covering the battery.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Lift up and remove the back panel. Lift up and remove the back panel. Lift up and remove the back panel.
    • Lift up and remove the back panel.
  5. After removing the back panel, use the             spudger to lift and detach the Battery Flux Cable from the Motherboard. After removing the back panel, use the             spudger to lift and detach the Battery Flux Cable from the Motherboard.
    • After removing the back panel, use the spudger to lift and detach the Battery Flux Cable from the Motherboard.
  6. Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape. Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape. Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape.
    • Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape.
Conclusione
After completing this guide, calibrate your newly-installed battery.
Altre 10 persone hanno completato questa guida.
Jack Haseman
Membro da: 19/03/2018
1.282 Reputazione
6 Guide realizzate
Baylor, Team S3-G2, Williams Spring 2018 Membro di Baylor, Team S3-G2, Williams Spring 2018
BU-WILLIAMS-S18S3G2
4 Membri
6 Guide realizzate
my moto e4 plus screen is freezing , how can we unfreeze please advise
rajamfaisal - Replica
This is the only tutorial that looks like my phone inside, even tho they’re all supposed to be Moto E4 Plus. All the ones on YouTube look different, screws in different places, etc.
Brad Rathernotsay - Replica
Hi Brad,
Motorola released a few variants of Moto E4s. You can compare phone’s model number to figure out exactly which model you have. We unfortunately don’t have all the Motorola guides covered at this point, but we’re working on it!
Arthur Shi -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 73
Ultimi 30 Giorni: 355
Tutti i Tempi: 4,139
