Salta al contenuto principale
Motorola Moto E4 Motherboard Cover Replacement
Cosa ti serve
  1. Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: passo 1, immagine 1 di 2 Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: passo 1, immagine 2 di 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: passo 2, immagine 1 di 2 Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: passo 2, immagine 2 di 2
    • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
  3. Motorola Moto E4 Motherboard Cover Replacement: passo 3, immagine 1 di 2 Motorola Moto E4 Motherboard Cover Replacement: passo 3, immagine 2 di 2
    • Gently pry up the plastic cover from the gap between it and the phone edge.
    • Start on the right side as indicated by the first picture.
    • Continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
Conclusione
Altre 2 persone hanno completato questa guida.
Nate Tjepkema
Membro da: 01/24/19
1.254 Reputazione
7 Guide realizzate
Cal Poly, Team S2-G4, White Winter 2019 Membro di Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 21
Tutti i Tempi: 643
