Introduzione
Use this guide to remove or replace the Moto E4 front facing camera.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Cosa ti serve
Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
With the phone face down, lift the battery up by the labeled tab and remove it from the device.
Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
Detach the front facing cable ribbon connector using an iFixit opening tool and lift the camera out of position.
Altre 2 persone hanno completato questa guida.
