Salta al contenuto principale
Motorola Moto E Display Assembly Replacement
Cosa ti serve
  1. Motorola Moto E Display Assembly Replacement, Motherboard: passo 1, immagine 1 di 1
    • Turn off the device before beginning.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
  2. Motorola Moto E Display Assembly Replacement: passo 2, immagine 1 di 1
    • Unscrew the 14- 4mm screws using a T4 Torx driver head.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  3. Motorola Moto E Display Assembly Replacement: passo 3, immagine 1 di 1
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
  4. Motorola Moto E Display Assembly Replacement: passo 4, immagine 1 di 1
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
  5. Motorola Moto E Display Assembly Replacement: passo 5, immagine 1 di 1
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
  6. Motorola Moto E Display Assembly Replacement: passo 6, immagine 1 di 1
    • Unscrew the 3- 1mm screws using the T4 torx driver head.
  7. Motorola Moto E Display Assembly Replacement: passo 7, immagine 1 di 1
    • Lift up on the white plastic mount.
    • Pull the orange ribbon cable out gently.
  8. Motorola Moto E Display Assembly Replacement: passo 8, immagine 1 di 2 Motorola Moto E Display Assembly Replacement: passo 8, immagine 2 di 2
    • Gently pull the black ribbon cable out.
  9. Motorola Moto E Display Assembly Replacement: passo 9, immagine 1 di 1
    • Using the metal spudger, pry the motherboard away from the screen assembly.
  10. Motorola Moto E Display Assembly Replacement, Display Assembly: passo 10, immagine 1 di 1
    • Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
    • The phone will be extremely hot. Avoid direct contact with metal pieces.
  11. Motorola Moto E Display Assembly Replacement: passo 11, immagine 1 di 1
    • Gently slide the metal spudger underneath the screen and pry it away from the backing.
    • Move the metal spudger under the digitizer and along the entire length of the phone to separate the screen from the adhesive.
    • If the screen was broken, glass shards may come off of the screen and puncture skin.
  12. Motorola Moto E Display Assembly Replacement: passo 12, immagine 1 di 1
    • Continue to heat and separate until the screen comes completely apart from the rest of the phone.
  13. Motorola Moto E Display Assembly Replacement: passo 13, immagine 1 di 1
    • To put the new screen on, press the new screen and digitizer into place, and then reapply heat to adhere the new screen.
Conclusione
Altre 23 persone hanno completato questa guida.
Alex Craig
Membro da: 03/11/15
2.596 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 45
Tutti i Tempi: 30,856
