Salta al contenuto principale
Motorola Moto 360 Rear Cover Replacement
Cosa ti serve
  1. Motorola Moto 360 Rear Cover Replacement, Rear Cover: passo 1, immagine 1 di 1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 Rear Cover Replacement: passo 3, immagine 1 di 2 Motorola Moto 360 Rear Cover Replacement: passo 3, immagine 2 di 2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 Rear Cover Replacement: passo 4, immagine 1 di 1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
Conclusione
Altre 9 persone hanno completato questa guida.
Cole Twitchell
Membro da: 01/30/15
1.679 Reputazione
2 Guide realizzate
Cal Poly, Team 17-32, Amido Winter 2015 Membro di Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Membri
18 Guide realizzate
Un commento
How does this *rear cover replacement* count as "no parts required"?
Kyle Mitchell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 12,597
