Salta al contenuto principale
Motorola Moto 360 O-Ring Replacement
Cosa ti serve
  1. Motorola Moto 360 O-Ring Replacement, Rear Cover: passo 1, immagine 1 di 1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 O-Ring Replacement: passo 3, immagine 1 di 2 Motorola Moto 360 O-Ring Replacement: passo 3, immagine 2 di 2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 O-Ring Replacement: passo 4, immagine 1 di 1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
  4. Motorola Moto 360 O-Ring Replacement, O-Ring: passo 5, immagine 1 di 2 Motorola Moto 360 O-Ring Replacement, O-Ring: passo 5, immagine 2 di 2
    • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
  5. Motorola Moto 360 O-Ring Replacement: passo 6, immagine 1 di 1
    • Pinch the green rubber O-Ring and slide it off of the watch.
    • The O-Ring is delicate and is easily severed. Use care around sharp objects.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 17-32, Amido Winter 2015 Membro di Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Membri
18 Guide realizzate
3 Commenti
Where can you get your hands on a replacement o'ring?!
James S - Replica
I broke my o-ring. Any ideas where I could get a raplacement?
Simon Hölz - Replica
i think you should not take the o ring. i was replaceing the battery without take the O ring
cahyanto emanuel nur - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,711
