Salta al contenuto principale
Motorola MOTO W755 Cell Phone Top Panel Replacement
Cosa ti serve
  1. Motorola MOTO W755 Cell Phone Top Panel Replacement, Battery: passo 1, immagine 1 di 2 Motorola MOTO W755 Cell Phone Top Panel Replacement, Battery: passo 1, immagine 2 di 2
    • Using your finger, press down on the clip holding the back cover on
    • Pull the back cover off.
  2. Motorola MOTO W755 Cell Phone Top Panel Replacement: passo 2, immagine 1 di 2 Motorola MOTO W755 Cell Phone Top Panel Replacement: passo 2, immagine 2 di 2
    • Place thumb and index finger in the spaces on either side of the battery.
    • Pull battery out.
  3. Motorola MOTO W755 Cell Phone Top Panel Replacement, Top Panel: passo 3, immagine 1 di 3 Motorola MOTO W755 Cell Phone Top Panel Replacement, Top Panel: passo 3, immagine 2 di 3 Motorola MOTO W755 Cell Phone Top Panel Replacement, Top Panel: passo 3, immagine 3 di 3
    • Use the plastic opening tool to pull peel back screen cover.
    • Gently peel back the screen cover from the speaker slit.
    • Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
  4. Motorola MOTO W755 Cell Phone Top Panel Replacement: passo 4, immagine 1 di 3 Motorola MOTO W755 Cell Phone Top Panel Replacement: passo 4, immagine 2 di 3 Motorola MOTO W755 Cell Phone Top Panel Replacement: passo 4, immagine 3 di 3
    • Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner.
    • Move the opening tool around the phone counter clockwise.
    • Pop the plastic cover off by twisting the plastic covering tool.
  5. Motorola MOTO W755 Cell Phone Top Panel Replacement: passo 5, immagine 1 di 2 Motorola MOTO W755 Cell Phone Top Panel Replacement: passo 5, immagine 2 di 2
    • Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone
    • Move the plastic opening tool around the phone until part of the casting is popped off.
    • You will need to pop in the four plastic fasteners individually from the metal casing to remove it
    • Be careful not to rip the cable ribbons that are attached to the logic board and casing
  6. Motorola MOTO W755 Cell Phone Top Panel Replacement: passo 6, immagine 1 di 1
    • Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
  7. Motorola MOTO W755 Cell Phone Top Panel Replacement: passo 7, immagine 1 di 1
    • You now have the top panel completely detached.
Conclusione
Cal Poly, Team 1-3, Regan SU 2012 Membro di Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,901
