Salta al contenuto principale
Motorola MBP667CONNECT Speaker Replacement
Cosa ti serve
  1. Motorola MBP667CONNECT Speaker Replacement, Camera Stand: passo 1, immagine 1 di 2 Motorola MBP667CONNECT Speaker Replacement, Camera Stand: passo 1, immagine 2 di 2
    • Remove two 5 mm Phillips #1 screws from the bottom of the camera stand.
  2. Motorola MBP667CONNECT Speaker Replacement: passo 2, immagine 1 di 1
    • Use a nylon spudger to remove the casing.
  3. Motorola MBP667CONNECT Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the two 5 mm Phillips #1 screws attached to the black plastic under the casing.
  4. Motorola MBP667CONNECT Speaker Replacement: passo 4, immagine 1 di 2 Motorola MBP667CONNECT Speaker Replacement: passo 4, immagine 2 di 2
    • Remove the black circular plastic part.
  5. Motorola MBP667CONNECT Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the white plastic wire housing beneath the black plastic.
  6. Motorola MBP667CONNECT Speaker Replacement: passo 6, immagine 1 di 2 Motorola MBP667CONNECT Speaker Replacement: passo 6, immagine 2 di 2
    • Now, remove the bottom of the stand by pulling it from the camera.
  7. Motorola MBP667CONNECT Speaker Replacement, Speaker: passo 7, immagine 1 di 3 Motorola MBP667CONNECT Speaker Replacement, Speaker: passo 7, immagine 2 di 3 Motorola MBP667CONNECT Speaker Replacement, Speaker: passo 7, immagine 3 di 3
    • Remove the Phillips #1 screws on the back of the device.
    • Use a nylon spudger to remove the casing. This will separate the frontside of the camera from the backside.
  8. Motorola MBP667CONNECT Speaker Replacement: passo 8, immagine 1 di 2 Motorola MBP667CONNECT Speaker Replacement: passo 8, immagine 2 di 2
    • Now locate the brackets by the speaker on the frontside of the camera and use the metal spudger to carefully disconnect from casing.
    • Continue to use the metal spudger to carefully disconnect the remaining brackets from the casing.
  9. Motorola MBP667CONNECT Speaker Replacement: passo 9, immagine 1 di 2 Motorola MBP667CONNECT Speaker Replacement: passo 9, immagine 2 di 2
    • Using the soldering iron, desolder the speaker wires that are attached to the circuit board.
    • Use caution while handling the soldering iron. This tool gets very hot!
    • After desoldering the speaker wires, remove the wires from the circuit board.
    • Thread the wires from the new speaker wires through the holes in the circuit board. Using the soldering iron, re-solder the wires to the circuit board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 191
