Salta al contenuto principale
Motorola MBP667CONNECT Circuit Board Replacement
Cosa ti serve
  1. Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: passo 1, immagine 1 di 3 Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: passo 1, immagine 2 di 3 Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: passo 1, immagine 3 di 3
    • Remove the two 5 mm Phillips #1 screws on the back of the camera.
    • Use a nylon spudger to remove the casing.
  2. Motorola MBP667CONNECT Circuit Board Replacement: passo 2, immagine 1 di 3 Motorola MBP667CONNECT Circuit Board Replacement: passo 2, immagine 2 di 3 Motorola MBP667CONNECT Circuit Board Replacement: passo 2, immagine 3 di 3
    • Remove the brackets by the speaker on the front side of the camera using the metal spudger.
    • Continue to use the metal spudger to carefully disconnect remaining brackets from casing.
    • Remove the two 5mm Phillips #1 screws on the backside of the camera.
  3. Motorola MBP667CONNECT Circuit Board Replacement: passo 3, immagine 1 di 3 Motorola MBP667CONNECT Circuit Board Replacement: passo 3, immagine 2 di 3 Motorola MBP667CONNECT Circuit Board Replacement: passo 3, immagine 3 di 3
    • Use the nylon spudger to remove the circuit board from the plastic casing for the backside of the camera.
    • Remove the two 5 mm Phillips #1 screws on the black circle receiver housing.
    • Now that the black circle is detached, use a nylon spudger to remove the white plastic circle from the casing.
  4. Motorola MBP667CONNECT Circuit Board Replacement: passo 4, immagine 1 di 2 Motorola MBP667CONNECT Circuit Board Replacement: passo 4, immagine 2 di 2
    • You will now be able to carefully pull the receiver wire through the gap in the casing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 426
