Salta al contenuto principale
Motorola MBP667CONNECT Battery Replacement
Cosa ti serve
  1. Motorola MBP667CONNECT Battery Replacement, Battery: passo 1, immagine 1 di 1
    • The battery casing is on the back of the monitor housing.
  2. Motorola MBP667CONNECT Battery Replacement: passo 2, immagine 1 di 2 Motorola MBP667CONNECT Battery Replacement: passo 2, immagine 2 di 2
    • Notice the little crevice at the bottom of the baby monitor. This is how the lid is removed. Simply put pressure with your finger to the crevice and lift.
    • Remove the battery casing lid from the back of the monitor housing.
  3. Motorola MBP667CONNECT Battery Replacement: passo 3, immagine 1 di 1
    • There is a plastic part connecting the wires of the battery to the device.
    • Disconnect the battery wiring from the monitor battery connection.
  4. Motorola MBP667CONNECT Battery Replacement: passo 4, immagine 1 di 1
    • Remove and discard the old battery and replace it with a new battery.
Conclusione
Un commento
just bought the battery linked and it has a slightly different, incompatible fitting. If i find one that works I’ll post…
Alex Chassy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 25
Tutti i Tempi: 5,234
