Salta al contenuto principale
Motorola Lapdock 100 Battery Replacement
Cosa ti serve
    1. Motorola Lapdock 100 Battery Replacement, Lower Case: passo 1, immagine 1 di 2 Motorola Lapdock 100 Battery Replacement, Lower Case: passo 1, immagine 2 di 2
      • To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
      • You do not need to remove any keys to unclip the keyboard. We did this for picture purposes only.
      Chiedi a FixBot
      Aggiungi Commento
    2. Motorola Lapdock 100 Battery Replacement: passo 2, immagine 1 di 1
      • You can use a small metal spudger to depress each tab to avoid scratching the keyboard.
      Chiedi a FixBot
      Aggiungi Commento
    3. Motorola Lapdock 100 Battery Replacement: passo 3, immagine 1 di 1
      • Lift up keyboard so that you are able to see the ribbon cable connected to the contact.
      Chiedi a FixBot
      Aggiungi Commento
    4. Motorola Lapdock 100 Battery Replacement: passo 4, immagine 1 di 2 Motorola Lapdock 100 Battery Replacement: passo 4, immagine 2 di 2
      • Flip up the ZIF connector holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the ribbon cable.
      Chiedi a FixBot
      Aggiungi Commento
    5. Motorola Lapdock 100 Battery Replacement: passo 5, immagine 1 di 2 Motorola Lapdock 100 Battery Replacement: passo 5, immagine 2 di 2
      • After we remove the Keyboard, you can clearly see the screws under it. Remove the ten 3mm long phillips head screws.
      Chiedi a FixBot
      Aggiungi Commento
    6. Motorola Lapdock 100 Battery Replacement: passo 6, immagine 1 di 3 Motorola Lapdock 100 Battery Replacement: passo 6, immagine 2 di 3 Motorola Lapdock 100 Battery Replacement: passo 6, immagine 3 di 3
      • Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom.
      Chiedi a FixBot
      Aggiungi Commento
    7. Motorola Lapdock 100 Battery Replacement: passo 7, immagine 1 di 2 Motorola Lapdock 100 Battery Replacement: passo 7, immagine 2 di 2
      • Use a plastic prying tool to take off the bottom case. Make sure that all of the clips are unclipped before trying to remove the case.
      Chiedi a FixBot
      Aggiungi Commento
    1. Motorola Lapdock 100 Battery Replacement, Battery: passo 8, immagine 1 di 2 Motorola Lapdock 100 Battery Replacement, Battery: passo 8, immagine 2 di 2
      • Unplug battery from motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    2. Motorola Lapdock 100 Battery Replacement: passo 9, immagine 1 di 1
      • Remove the battery.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
1Commento della guida
where can i buy a bettery
Justin Craig - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 29
Ultimi 30 giorni: 59
Tutti i Tempi: 3,191
