Salta al contenuto principale
Motorola Krzr K1m Battery Replacement
  1. Motorola Krzr K1m Battery Replacement, Battery: passo 1, immagine 1 di 2 Motorola Krzr K1m Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
  2. Motorola Krzr K1m Battery Replacement: passo 2, immagine 1 di 1
    • While pushing down on the silver tab, slide the back cover towards the silver tab.
    • Remove the back cover.
  3. Motorola Krzr K1m Battery Replacement: passo 3, immagine 1 di 1
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Replace the old battery with the new battery.
    • Follow all of the steps to remove the battery in reverse order to reassemble.
Conclusione
Cal Poly, Team 11-1, Forte Winter 2010 Membro di Cal Poly, Team 11-1, Forte Winter 2010
CPSU-FORTE-W10S11G1
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 5,553
