Salta al contenuto principale
Motorola Edge Plus 2022 Display Assembly Replacement
Cosa ti serve
  1. Motorola Edge Plus 2022 Display Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Press and hold the power button for 7 seconds.
    • You will know the phone is fully powered off when the Motorola logo appears on the screen.
  2. Motorola Edge Plus 2022 Display Assembly Replacement: passo 2, immagine 1 di 1
    • Insert a paperclip or SIM card ejector into the small hole located at the bottom of phone.
    • Gently push to release and remove the SIM card.
  3. Motorola Edge Plus 2022 Display Assembly Replacement: passo 3, immagine 1 di 3 Motorola Edge Plus 2022 Display Assembly Replacement: passo 3, immagine 2 di 3 Motorola Edge Plus 2022 Display Assembly Replacement: passo 3, immagine 3 di 3
    • Use an iOpener, heat gun, or hairdryer to gently heat the perimeter of the phone.
    • Insert and slide the iFixit opening pick around heated edges to sever the adhesive securing the rear cover.
  4. Motorola Edge Plus 2022 Display Assembly Replacement: passo 4, immagine 1 di 3 Motorola Edge Plus 2022 Display Assembly Replacement: passo 4, immagine 2 di 3 Motorola Edge Plus 2022 Display Assembly Replacement: passo 4, immagine 3 di 3
    • Gently remove the back cover using the suction handle or your bare hands.
  5. Motorola Edge Plus 2022 Display Assembly Replacement: passo 5, immagine 1 di 2 Motorola Edge Plus 2022 Display Assembly Replacement: passo 5, immagine 2 di 2
    • While applying light pressure, remove the camera bezel cover by sliding the jimmy along the edges.
  6. Motorola Edge Plus 2022 Display Assembly Replacement: passo 6, immagine 1 di 2 Motorola Edge Plus 2022 Display Assembly Replacement: passo 6, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the twelve 1.5 mm black screws.
    • In case a screw gets lost, the exact specifications for all screws in this guide are OEM MOTOROLA EDGE+ PLUS 5G UW.
  7. Motorola Edge Plus 2022 Display Assembly Replacement: passo 7, immagine 1 di 3 Motorola Edge Plus 2022 Display Assembly Replacement: passo 7, immagine 2 di 3 Motorola Edge Plus 2022 Display Assembly Replacement: passo 7, immagine 3 di 3
    • Remove the logic board by lifting gently with the flat end of the spudger.
  8. Motorola Edge Plus 2022 Display Assembly Replacement: passo 8, immagine 1 di 3 Motorola Edge Plus 2022 Display Assembly Replacement: passo 8, immagine 2 di 3 Motorola Edge Plus 2022 Display Assembly Replacement: passo 8, immagine 3 di 3
    • Use the flat end of a spudger to to pry up and disconnect the two press connectors on either side of the battery.
    • Located in the bottom left corner of the battery, remove the tape (black in the image) with a spudger.
  9. Motorola Edge Plus 2022 Display Assembly Replacement: passo 9, immagine 1 di 3 Motorola Edge Plus 2022 Display Assembly Replacement: passo 9, immagine 2 di 3 Motorola Edge Plus 2022 Display Assembly Replacement: passo 9, immagine 3 di 3
    • Gently lift the battery up using the black spudger and remove.
    • Applying too much force when removing the battery may damage it. Take care not to bend, warp, or puncture the battery.
    • Apply a few drops of isopropyl alcohol if the battery is tightly adhered.
  10. Motorola Edge Plus 2022 Display Assembly Replacement, Display Assembly: passo 10, immagine 1 di 3 Motorola Edge Plus 2022 Display Assembly Replacement, Display Assembly: passo 10, immagine 2 di 3 Motorola Edge Plus 2022 Display Assembly Replacement, Display Assembly: passo 10, immagine 3 di 3
    • Use an iOpener or heat gun to heat the perimeter of the phone.
    • Only apply heat for 30-45 seconds. Using the iOpener for longer may damage the insides of the phone.
    • Insert an opening pick 3 mm into the seam between the display and chassis.
    • Slide the opening pick around the heated edges to sever the adhesive securing the display.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 36
Tutti i Tempi: 36
