Salta al contenuto principale
Motorola Edge (2021) Back Cover Replacement
Cosa ti serve
  1. Motorola Edge (2021) Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • To start you will need to soften the adhesive on the edges of the phone using two iOpeners.
  2. Motorola Edge (2021) Back Cover Replacement: passo 2, immagine 1 di 1
    • After the glue is soft, apply moderate force with the iFixit opening pick along the edge where the glue is located.
  3. Motorola Edge (2021) Back Cover Replacement: passo 3, immagine 1 di 1
    • After you have taken the glue off of the edges of the phone you can just easily pull the back cover off.
Conclusione
By following this guide, you have successfully learned how to remove the back cover of your Motorola Edge smartphone. Remember to handle the device with care and follow all safety precautions.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 46
