Salta al contenuto principale
Motorola E815 interiorscreen replacement
Cosa ti serve
  1. Motorola E815 interiorscreen replacement, Battery: passo 1, immagine 1 di 1
    • Locate the back cover release slide.
    • Use your finger to slide it down.
  2. Motorola E815 interiorscreen replacement: passo 2, immagine 1 di 1
    • Remove the back cover by pulling it away from the phone.
  3. Motorola E815 interiorscreen replacement: passo 3, immagine 1 di 2 Motorola E815 interiorscreen replacement: passo 3, immagine 2 di 2
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
  4. Motorola E815 interiorscreen replacement, Disassembling Motorola E815 Antenna: passo 4, immagine 1 di 1
    • Locate the antenna port on the top of the phone.
  5. Motorola E815 interiorscreen replacement: passo 5, immagine 1 di 2 Motorola E815 interiorscreen replacement: passo 5, immagine 2 di 2
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
  6. Motorola E815 interiorscreen replacement, Front Screen: passo 6, immagine 1 di 3 Motorola E815 interiorscreen replacement, Front Screen: passo 6, immagine 2 di 3 Motorola E815 interiorscreen replacement, Front Screen: passo 6, immagine 3 di 3
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using your T6 screwdriver.
  7. Motorola E815 interiorscreen replacement: passo 7, immagine 1 di 3 Motorola E815 interiorscreen replacement: passo 7, immagine 2 di 3 Motorola E815 interiorscreen replacement: passo 7, immagine 3 di 3
    • Grasp the top of the phone near the speaker.
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Detach the top section of the phone from the keypad section.
  8. Motorola E815 interiorscreen replacement: passo 8, immagine 1 di 2 Motorola E815 interiorscreen replacement: passo 8, immagine 2 di 2
    • Carefully insert the blue pry tool into the notch between the two halves of the top section of the phone.
    • Gently pry the two halves apart.
  9. Motorola E815 interiorscreen replacement: passo 9, immagine 1 di 1
    • Rotate the top section of the phone around so that you are looking at the outer screen.
    • Disconnect the cover from the outer screen side of the phone.
  10. Motorola E815 interiorscreen replacement: passo 10, immagine 1 di 3 Motorola E815 interiorscreen replacement: passo 10, immagine 2 di 3 Motorola E815 interiorscreen replacement: passo 10, immagine 3 di 3
    • Rotate the top section of the phone around so you are looking at the large screen.
    • Using your fingers, lift the protector off of the screen.
  11. Motorola E815 interiorscreen replacement: passo 11, immagine 1 di 1
    • Using the blue pry tool, gently remove the screen cover.
    • Since it is glued into place, it may take some maneuvering to remove.
  12. Motorola E815 interiorscreen replacement: passo 12, immagine 1 di 3 Motorola E815 interiorscreen replacement: passo 12, immagine 2 di 3 Motorola E815 interiorscreen replacement: passo 12, immagine 3 di 3
    • Turn the phone so that you can see the side metal clasps.
    • Using the blue lifter tool, snap the metal clasps off of screen body.
    • Proceed to snap all four corners of the metal cover off of the screen body.
  13. Motorola E815 interiorscreen replacement: passo 13, immagine 1 di 2 Motorola E815 interiorscreen replacement: passo 13, immagine 2 di 2
    • Using tweezers, gently detach the brown connecting strip from the back of the screen.
    • Separate the screen from the phone frame.
    • The front screen can now be accessed and replaced!
  14. Motorola E815 interiorscreen replacement, Inside Screen: passo 14, immagine 1 di 1
    • The inside screen can now be accessed for repair or replacement!
Conclusione
Zoie E
Membro da: 01/12/11
603 Reputazione
5 Guide realizzate
Cal Poly, Team 14-8, Forte Winter 2011 Membro di Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,199
