Parti
Nessuna parte richiesta.
Objective: remove the rear case from the Motorola Droid X phone.
  • Objective: remove the rear case from the Motorola Droid X phone.
    • This is what the Motorola Droid X looks like before disassembly. In the front, there is a large LCD touch screen.
Aggiungi Commento
INSTRUCTION: Turn the phone over so that the back faces up.
  • INSTRUCTION: Turn the phone over so that the back faces up.
Aggiungi Commento
  • Objective: remove the battery casing plate.
    • The case plate has a push and slide mechanism.
Aggiungi Commento
  • INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
  • INSTRUCTION 2: Slide down the battery case plate.
Aggiungi Commento
  • INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
Aggiungi Commento
  • Objective: remove the battery from the battery compartment.
Aggiungi Commento
  • INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
Aggiungi Commento
  • Objective: remove two small black screws from the back of the phone.
    • These two (2) screws help hold the phone together. They need to be removed by a Phillips Hex 2mm screwdriver,
Aggiungi Commento
  • INSTRUCTION: Remove two black screws from the back of the phone.
Aggiungi Commento
  • Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
    • The two plastic pieces are clipped onto the phone as covers. They are located at the top and the bottom of the phone.
Aggiungi Commento
  • INSTRUCTION: Flip the phone over to the front side.
Aggiungi Commento
  • INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone. It will pop off.
Aggiungi Commento
  • INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
Aggiungi Commento
  • Objective: remove four white screws from the corners of the screen.
    • These four (4) screws help hold the phone together. Use a Phillips Hex 2mm screwdriver
Aggiungi Commento
  • INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
Aggiungi Commento
  • INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
Aggiungi Commento
  • Objective: remove the rear case from the phone in order to provide access to inside the phone.
    • The phone is now held together by the casing alone. You need to pop the two halves apart.
Aggiungi Commento
  • INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the casing. They will pop apart.
Aggiungi Commento
  • Now you are ready to access the internal circuits of the phone.
Aggiungi Commento
  • The objective of the guide is to remove the motherboard from the camera.
    • The mother board is an L-shaped green circuit board.
Aggiungi Commento
  • In order to start, the rear case should have been removed. Follow the rear case removal guide for that procedure.
Aggiungi Commento
  • Let's start. The objective of the following two steps is to remove the circuit connectors connected to the mother board.
    • They are "clip-on" type connectors which have a black leathery coating. The connectors are located at the lower bottom left part of the "L-Shaped" motherboard.
    • There are two connectors with the larger one overlapping the smaller one. You can disconnect them either by hand or with the iFixit tool.
Aggiungi Commento
  • INSTRUCTION: Disconnect the larger connector on the top by pulling on the edge of the black coated connector. It will pop off.
Aggiungi Commento
  • INSTRUCTION: The smaller connector will become visible once the larger one is disconnected. Disconnect it also the same way as before.
Aggiungi Commento
  • Objective: disconnect the white wire connected to the motherboard.
    • The wire is visible at the upper left of the "L-shaped" Motherboard. Each end of the white wire is connected by a circular pop-on connector.
Aggiungi Commento
  • INSTRUCTION: Grab and pull up on the silver connector that is at the end of the white wire connected to the motherboard until it pops off.
Aggiungi Commento
  • Objective: separate the motherboard from the rest of the phone.
    • The motherboard is held in place by two silver clasps on the left side of the phone.
Aggiungi Commento
  • INSTRUCTION: Use the iFixit tool to pry the clasps open. This will free the motherboard from the case.
Aggiungi Commento
  • Objective: detach the camera component from the phone.
    • The camera component is located at the upper left part of the phone, right above the white wire mentioned previously. The camera is square.
Aggiungi Commento
  • INSTRUCTION: Grab the camera component and pull it out of its casing. Keep the camera connected to the mother board.
Aggiungi Commento
  • Objective: disconnect a circuit connector from underneath the motherboard to finish the process.
    • The circuit connector is a gold and black colored "clip-on" type connector located in the middle left side of the phone. It is connected to the underside of the motherboard.
Aggiungi Commento
  • INSTRUCTION: Slowly lift up the motherboard as you would turn a page.
    • The motherboard is still connected to the phone.'''
Aggiungi Commento
  • INSTRUCTION: Use your fingertips to grab a edge of the connector and pop it off.
Aggiungi Commento
  • Conclusion: Now, you have successfully removed the motherboard.
  • At this point, you will be left with the following: 2 black screws, 4 silver screws, 1 motherboard, 1 camera, 1 rear case, 1 battery, 2 plastic pieces from the front case, and the rest of the phone.
Aggiungi Commento
Conclusione
Yong hoon choun
Membro da: 08/10/2012
120 Reputazione
1 Guida realizzata
Ohio State, Team 1-1, Voss Fall 2012 Membro di Ohio State, Team 1-1, Voss Fall 2012
OSU-VOSS-F12S1G1
3 Membri
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 620
